Refrigerators Logo
Anonymous Posted on Jun 11, 2013
Whirlpool ice dispenser not working - Refrigerators
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Jun 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
19227
Points
28
It could be clogged. Without more info its rather hard to answer. Depending on where you water comes in, the line could be kinked or it could be loose. If no water leaking probably not loose. More commonly the line going from refrigerator to water coming into it is kinked or the line is clogged. Could also be clogged where ice comes out, especially if you are getting water but no ice. Then empty all the ice from the holding box, then clean any ice off that has built up around the ice lever area. Hope this help, Anthony
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 14, 2007
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Anonymous
  • 619 Answers
  • Posted on Dec 31, 2007
SOURCE: whirlpool ice dispenser not working
motor drive shut down/reset if their is available
Anonymous
  • Posted on Jan 04, 2008
SOURCE: ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jun 05, 2009
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? [email protected]
Anonymous
  • 986 Answers
  • Posted on Nov 11, 2009
SOURCE: Icemaker doesn't work on whirlpool gd5rhaxnb00.
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to [email protected]. Thank you.
1helpful
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Ice dispenser not working on whirlpool side by side.
Andy_hall800, we're sorry to learn of your experience with the ice maker on your Refrigerator. We apologize, but we wouldn't be able to provide you with any technical assistance due to we aren't certified Technicians. We recommend service.
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
2answers
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Ice and water dispenser
Ice Will not dispense
Check that the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the "Unlock" or "Locked" button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.          http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=110&p_created=1147725595&p_sid=lTIkCMOi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEmcF9wcm9kcz0xOTkmcF9jYXRzPSZwX3B2PTEuMTk5JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9d2F0ZXIgZGlzcGVuc29y&p_li=&p_topview=1
2answers
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
