Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi vs45va1 I have about 10 skinny horizontal lines across the screen. they are very annoying.
  • Anonymous Aug 20, 2007
    Sorry. I forgot to add 10 skinny red lines.
    Genius:
  • 1,153 Answers
. CHECK C7613 (10UF 16V) FOR LEAKY/SHORTED CONDITION. LOCATED ON PCB-TERMINAL AT IC7602 PIN 4 CHECK FOR LEAKY OR SHORTED C5A1 OR C5A2,BOTH ARE (2.2UF 50V) ON PIN 2 OF IC5A0.LOCATED ON THE SIDE-PIN-PCB
Posted on Sep 07, 2007
    Sniper:
  • 140 Answers
You have some leaky filter caps. They are: C2C52 = 10 MFD 50 VOLT (off the base of Q2C51 on the signal board)Also check C2P05 = 100 MFD 16 VOLT (off pin #3 of IC2P01 on the signal board) and C2P03,C2P08 = 100 MFD 16 VOLT both on the signal board.
Posted on Aug 20, 2007
SOURCE:
Limes across screen when first turned on, by turning off and on sometimes fixes it, what could cause that problem?
If the lines are colored or even look 3d it is a convergence problem--if other lines it will depend on what they look like and what the model number is.
May 27, 2012 | Mitsubishi Televison & Video
Horizontal Lines in Picture, Picture Possibly Dimmer
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits
Jul 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Thin white line on screen
this is a screen fault... this should be sent to the maufacturer for repair/replacement if still in warranty
Sep 28, 2008 | Durabrand DVD-1002 DVD Player
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Mitsubishi VS-45607 45" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
