Back to:
Tags:
D-Link RangeBooster G  DPR-1260  Print Server
DPR-1260, HP All in one 2210, and IE7 (by 2 users)
posted by Tothehoop on Aug 20, 2007
i just bought the DPR 1260 on reccomendation from someone...
the printer was recognized without issue, but when i tried to scan the scanner would hang.
I updated the firmware to the v1.21 and then one of my XP workstations couldn't print, and when i would go to the web console, there were IE errors all over the place(i can't change languages, no devices were detected, etc). The wierd thing is every other PC on my network was fine. I have tried all four firmwares with a varying degree of success. I am at 1.12 now, so my primary workstation could print...but i still can't scan from it..I get "low memory please try again later" errors.
Any thoughts? this is set up wired...wireless is off as i already have a wireless network setup.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by POBox, posted on Jun 05, 2008
I've installed a DPR-1260 wireless print router. It recognises and operates my Canon PIXMA iP4500 printer OK, but the DPR-1260 sees the Canon MF4150 as a fax only, and neither the printer or scanner drivers. I know the MF4100 series isn't one of the 'tested' printers for the DPR-1260 router. Can you suggest how to get the DPR1260 to recognise at least the printer function of the Canon MF4150?
Best Solution
posted on Aug 20, 2007
Thanks for Trying (70)
pastorm
Rank:Wiz Wiz
Rating: 77%, 147 votes
Make sure your printer is on the compatibility list provided by D-Link. The list is in the following link:
http://support.dlink.com/faq/view.asp?pr...
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on DPR-1260, HP All in one 2210, and IE7:
I don't want to Accept this solution
Solution #2
posted on Oct 07, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
What kind of solution is this ? This is an insult of intelligence.
Thank You!
Can you Help with these Print Servers problems?
Print Servers
examples of graphs of the fundamental functions and...
D-Link RangeBooster G DPR-1260 (DPR1260)...
The initiall set up went ok it printed test page ,I switch...
i have a pc and a laptop with all the features.i want to...
Print Servers
I've changed the cartrige and I did remove the tape before...
I have reciently installed a D-Ling 1260. The directions...
Loading problems.
Repair Service
Find Print Server Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
