Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Convergence problem can anyone tell me how to change the convergence circuit on a av48wp30. Do you recommand that i get a service repair person. thanks moe
  • 1 more comment
  • bigmoe Aug 20, 2007
    thanks so much
  • John_The_Cop Nov 02, 2007
    Hello! I am always on a tight budget and my bigscreen (same model as being talked about here) just started spazzing out. Sounds like the convergence chip I have been reading about. I am somewhat tech abled so I ventured into the cabinet and found the convergence board and the chips desribed. I have found the chips all over the net from 5 bucks up to 50 for jvc branded ones. My question is, will any work such as the Sanyo branded ones I have found?
    Thanks in advance,
    John the Cop in Ok
    Oh I forgot to mention, The spazzing occurred in the snap of a finger while I was watching television. At first I thought that the program had changed to 3-D!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
This is by far the easiest TV to replace the convergence ic's - you don't even have to take the back off! Remove the front panel by removing the screws on the back edges secured to the front to the cabinet,also remove the small screw behind the front control door - the front comes off - remove access panel,there you will see the convergence board right in front - unplug the connectors to the board - pull it out and replace the ic's (2)part# STK392-110. Also check for any burnt or discolored resistors near the ic's - they may need replacing
Posted on Aug 20, 2007
SOURCE:
Double faces with red 'halo' around people...after TV 'popped' and went off then back on.
Replace the convergence ICs and resistors. You can get the JVC repair kit called the AV48WP30 - AV65wp30 convergence repair kit from www.tvrepairworld.com which contains the ICs, Resistors, and the CD with repair instructions.
May 25, 2011 | JVC AV-56WP30 56" Rear Projection...
Display out of focus
convergence issue. The JVC repair kit called the AV48wp30 - AV65WP30 convergence repair kit is the correct kit for your model and symptom. Its available from www.tvrepairworld.com and the kit contains the parts and the CD with repair instructions.
Feb 16, 2011 | JVC AV-56WP30 56" Rear Projection...
The picture is not clear-the colors do not line up-they are not aliened
Convergence failure is causing that. You can get the AV48WP30 Convergence repair kit from www.tvrepairworld.com the kit contains the IC's Resistors and the CD with step by step repair instructions.
Aug 15, 2010 | JVC AV-48WP30 48" Rear Projection...
My jvc model # av-48wp30 tv has a blue shadow
Convergence needs repair. The AV48WP30 convergence repair kit from www.tvrepairworld.com has the parts and the CD with step by step repair instructions.
Aug 08, 2010 | JVC AV-48WP30 48" Rear Projection...
The red tube is not acting right. When you go to convergence, the red lines are not straight. They are concave, I think is how you would describe it.
You need to install a convergence repair kit. You can get the AV48WP30 convergence repair kit at www.tvrepairworld.com the kit contains the parts and the Cd with detailed photos with instructions.
Dec 08, 2009 | JVC AV-48WP30 48" Rear Projection...
Turns on then in 1 second right back off
IF THE SET SHUTS OFF CHECK TO SEE IF THE POWER LIGHT JUST BLINKS(MOST OF THESE THE LIGHT IS BLUE)
A constant blinking of the power light means usually a short-----
The most common cause for this in AV48wp30 is a short in the convergence circuit of the set.
Let me know if you have the constantly blinking power light and I can tell you an easy way to prove without replacing any parts if the convergence circuit is your problem.
If you have a convergence problem causing this I can tell you what parts are needed and where to get them and how to do the fix yourself.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Color
you need to install a convergence repair kit which should take care of that issue. Heres a link to the repair kit for your model. The kit contains the parts and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Jul 05, 2009 | JVC AV-56WP30 56" Rear Projection...
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
I have a JVC av48wp30 tv with a convergence problem. I have read about changing the 2 stk392-110 ICs. Do I also need to change the resistor? Also, where can I get the schematics and instructions on how...
Go to this link they have replacement Convergence ICs and they provide free instalation instructions with pictures plus free on line tech support so you can do the repairs yourself.
May 01, 2008 | Televison & Video
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
