Question about Hitachi 53FDX01B 53" Rear Projection Television
Tv will not turn on
Blue screen with caption that said powerlost and time not set. pulled plug, next morning try again just blinking green light and it went out... any suggestions...
  • 927 Answers
Good Day;
I hope you have solved this concern by now, if not call an Authorized Service Center and have them come out and give you a written estimate. Good Luck, big IRISH.
Posted on Sep 09, 2008
SOURCE:
My Mitsu Ws48511 green light blinks for about 2 minutes then stops. After another minute, it begins to blink again. It continues this until I unplug the tv. Then it often blinks for up to 8 hours before...
First: the blinking green light means the set has a DM unit in it. It should when unplugged and plugged back in blink for 70 seconds and then go out.
One of two things is wrong here:
1) The DM unit (large metal box on the left as you look from the back) has several capacitors and fuses that can fail.
2) Try this: Pull front speaker grill off: held on with plastic pegs.
Remove the inspection plate you will find in back of it.
Note the two groups of wires that come from the front keyboard; follow them down and to the right and unplug the two plugs you find; most have two and they are different sizes and marked so you cannot get them wrong.
The idea here is to disconnect the entire front keyboard and the reset switch from the set.
You can still turn the set on with the remote.
If the set now works--you have two choices----use the set with a remote and the keyboard not connected.
Remove the entire screen assembly and remove and or replace the reset switch.
IF DISCONNECTING THE KEY BOARD DOES NOT CURE IT--the Dm unit is bad---either change the four caps--lots of sites sell kits for this OR send the entire DM unit out for repair/rebuild to someone like PTS ELECTRONICS.
THE BLINKING GREEN LIGHT IS THE DM UNIT TRYING TO BOOT UP--LIKE A COMPUTER.
iF THIS INFORMATION TOLD YOU SOMETHING YOU DID NOT KNOW, rate this solution as very helpful as I do this here for free.
make a comment here if you need additional help---I am here to help.
REGARDS, SD TECH
Aug 15, 2010 | Mitsubishi WS48511 48" Rear Projection...
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
5 blink red lights
Replace your Lamp # XL2100u Mats has them in stock 1-800-628-1118
Mar 24, 2010 | Sony Grand WEGA KF50WE620 Television
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Won't turn on blinking red where green power lights should be.
plase open the cpu & plug in the ram in the right order.
Dec 10, 2008 | HP Compaq d530 PC Desktop
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Tv won't turn on.
call tech ...suggest troubleshoot power pack.
Aug 20, 2007 | GE 46GW947 46" Rear Projection Television
JVC PD-42WV74 tv turned itself off and unable to turn it back on. Green light blinks on receiver and TV.
Unplug the TV set, after a few minutes, plug it back again. If you are lucky, the TV will be okay!
May 07, 2007 | JVC PD-42WV74 42 in. Plasma EDTV
Hitachi 53FDX01B 53" Rear Projection Television Logo
32 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
