Question about GE 46GW947 46" Rear Projection Television
Tv won't turn on.
Ws55011 ht1080 When I turned it on all I got was a blue screen, and it said powerlost and time not set. I have not been able too turn it back on. pulled plug next morning all I got was blinking green light. and It went out. Help Please.
  • netminderz Dec 15, 2007
    My tv wont turn on all the time. I have to take the rear cover off and then i just start moving wires and playing with connectors and then the tv comes on. When I turn the power on I can hear the tv energize but I cant get the television to work. Is there a quick fix that I can do myself.
Thanxs for the help, just curious the tv works great when it does come on. sometimes i can turn it off 5 times in a row , the next time the tv doesnt work again. would this relate to the same problem as before, the power pack? thankyou
Posted on Dec 15, 2007
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Call tech ...suggest troubleshoot power pack.
Posted on Nov 26, 2007
SOURCE:
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
Vizio LCD TV Model L37HDTV10A - I have attached a Digital TV Antenna to the proper input, but once I open the on screen display go to the DTV input and attempt to access the TV setting to program the...
Sometimes it takes a while for the TV to go through this set up such as a half hour to an hour. Just be patient an make sure the antenna is set to air.
Jun 20, 2011 | Televison & Video
I am not getting picture on my TV it stic on only one channel we are chengiong channel but same sound is comming also we are getting a blue coloured K on right hand side of TV
That blue K means you are in the service mode. Unplug your set and wait 30 seconds. Then at the same time you plug it back in, you need to be holding the volume down button and the input button.
The TV should turn back and the blue K should turn pink. Once this happens, press the volume and channel down button at the same time. A menu should come on the screen. With your remote, press the up arrow to reach the nest page. The first option should say INIT. Arrow to the right and hit enter. In a few seconds your screen should turn green and say success. Unplug the TV and wait 30 seconds. Plug the set back in and turn on your TV. You can then set your set back the way you want.
May 04, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My JVC LT42X579 blue light stays on it won't turn off.
If what you mean is that the blue screen won't turn off (after about 5 minutes), so you should go the your tv menu options and select how much time in the blue screen option (under 'picture' or something like that).
Nov 27, 2008 | Televison & Video
Toshiba 43" Rear Projection tv (Just show's Blue Screen)
Hi Chris,
It sounds like you have a tuner problem. Usally the set will turn blue if there is no signal to the set, which is first generated from the tuner. It could also be the processor on the main board, but I would look at the tuner first.
Good luck and I hope this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
May 28, 2008 | Toshiba 43H70 43" Rear Projection...
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Tv will not turn on
Good Day;
I hope you have solved this concern by now, if not call an Authorized Service Center and have them come out and give you a written estimate. Good Luck, big IRISH.
Aug 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
GE 46GW947 46" Rear Projection Television Logo
70 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
