Question about PfaFF Tiptronic 2040
Machine foot will not work
My machine foot will not work at all . The machine turns on but when you press the foot nothing happens. Anyone know where to get a foot for the 2040 that will not cost me an arm or leg. Thanks
  • Anonymous Aug 13, 2008
    I have the same problem. The foot control has been a bit iffy for a while now it's stopped working altogether. I sourced a new foot control but the price quoted is £96!!! I will try taking it apart and see what happens.
  • Anonymous Sep 12, 2008
    Same problem. The machine itself turns on, but the foot control doesn't do anything. Is it definitely the foot control or maybe something inside the machine wiring???
  • 3 Answers
I took a foot control apart and couldn't put it back together again. Get a new one and save the trouble.
Posted on Apr 27, 2008
  • 202 Answers
Have you taken the foot control apart yet? What have you got to lose. Possibly something came loose that you can put back in place? There are small carbon contacts that may be put back in place. Just remember to put it back togeather the same way you took it apart. Or keep an eye on eBay and ask questions. Mostlikely a generic footcontrol will work. Good luck. Rick
Posted on Aug 22, 2007
SOURCE:
My Bernina 1300 MDC serger stopped sewing. The light comes on and the machine makes the start up noise but, when I press the foot pedal, nothing happens.The foot works with other machines.
check to see if any thread is jammed inside the right turning side wheel in the core area at times there can be thread that flies in there and may stop the main belt turning.
Apr 08, 2017 | Bernina Sewing Machines
Foot control on my Juki 2010 sewing machine is not working, as if there's no power reaching it at all. There is power to my machine as indicated by light coming on when main power switch turned on.
Pam, Could be a bad/broken wire, may be repairable, you should take your pedal in to be tested, if diagnosed to be bad you may have to order a new replacement pedal. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Repair the Foot Control on Your Sewing Machine
http://www.sewingmachinesplus.com/foot-control-419451-003.php?gdftrk=gdfV210602_a_7c3285_a_7c15319_a_7cPID513
Sewing Parts Online Search
Juki Sewing Machines
Jun 09, 2016 | Juki Sewing Machines
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Nothing happens when I push the foot pedal
Please check the Stitch regulator & Presser foot lifter.
Jan 03, 2014 | Singer 7442 Mechanical Sewing Machine
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
Foot pedal doesn't work when pressed
you can either have that foot pedal checked or buy a new one
sewing machine parts
sewingpartsonline.com
sew4less.com
sewusa.com
premiersewing.com
ebay
Apr 12, 2012 | Sewing Machines
Sewing machine does not sew. Finished sewing something, turned it off, then turned it on a few hours later and it will not work. Light is on but nothing happens when the foot pedal is pressed. Took apart...
Call Singer at 1-800-4singer and ask for their advice, you do not want to void your warranty with not going to an authorized repair service if it comes to that. Good luck
Oct 07, 2010 | Singer 5050 Mechanical Sewing Machine
Bobbin Threading
Divot on needle must be installed facing bobbin case.
Apr 24, 2017 | Consew 199R-2A Sewing Machine
Sewing Machines Logo
176 people viewed this question
Top PfaFF Sewing Machines Experts
Douglas Plant
Douglas Plant
MissFixIt828
Level 1 Expert
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
