Question about Pioneer PD-F407 25-Disc CD Changer
Pioneer PD-F407 Not reading or displaying"No disc"
1.) I put the cd in both ways, got same result both times. 2.) No Lock on bottom. 3.) I cleaned the lense. I took the cover off and noticed that when the CD is taken from the "Slot", to be played/read, there is a little give or play with the securing plate and the CD sits in the position crooked. So the next time a CD was taken from the next slot, I tried to push the securing plate to secure the CD. I thought I fixed it because the CD started spinning and reading. Then it stopped and moved on to the next slot just like before. I have been to Pioneer's website a hundred times but it is not loading correctly or won't load at all and freezes. Can someone help me or at least tell me where I can go to get parts or get this CD player fixed? I have had it for a few years but I bet it has not even been played but a dozen times.
2 Suggested Answers
SOURCE:
  • 28 Answers
SOURCE: my Pd-f4o7 25 CD changer
Mechanical fault, monitor loading arm but most likely belts.
capital98
Posted on Dec 22, 2007
Need manual for PD-F407
It is availalbe as a Pdf file download for $5.00 at owners-manuals.com -
https://www.owner-manuals.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=+PD-F407&x=23&y=27&brand=PIONEER
Sep 17, 2012 | Pioneer Audio Players & Recorders
Pd f-407 wont pick up disc
This type of repair is tricky at best because it is a multi disc player. Some discs will jam together locking up the loading bay, also! the timing gear will go out sync, or the the plastic gears will show signs of ware causing gears to slip, the final aspect is broken worm gear and cogwheels cracked or missing a tooth. In order to repair unit must be dismantled to attempt the repair.
Apr 22, 2012 | Pioneer PD-F407 25-Disc CD Changer
Require a users manual for my pioneer file type compact disc player model PD-F407
Direct Download Link for manual :)
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/282719879PD-F407%20PRE1297A.pdf
Jun 14, 2011 | Pioneer Car Audio & Video
Hooked to speakers. no sound do i need a reciever? and if so what kind.
Yes, unless you're using self-powered speakers. Then there's the little matter of controlling volume. Otherwise, any amp or receiver that accepts the RCA or digital outputs. Find and read the manual.
BTW: how did you hook it to speakers?
Jun 13, 2011 | Pioneer PD-F407 25-Disc CD Changer
I have model PD-F407-- It will not play past disc 5. I can not get it to manually play any disc past 5 and it won't roll over from disc 5 to 6. If I punch in to play disc 9 it flashes disc 5 on the...
Check that no CD's have dropped behind the load tray. The same issues happened to me and I found 3 discs that had fallen out and were blocking the mechanism from going past disc 5
Dec 24, 2010 | Pioneer PD-F407 25-Disc CD Changer
It will pick up the cd's but won't play them. I have taken them out, cleaned them and put them back in. I have tried different cds in different slots and it will only pick them up but will not play any...
The laser head needs a clean with isopropanol. This needs to be stripped down and use a cotton bud on the laser head. You can buy a bottle of isoproponal from your local chemist.
Dec 05, 2009 | Pioneer PD-F407 25-Disc CD Changer
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
My Pd-f4o7 25 CD changer
capital98
Dec 19, 2007 | Pioneer PD-F407 25-Disc CD Changer
Pioneer PD-F407 25-Disc CD Changer Logo
298 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
