Question about Philips Magnavox 27MS343S 27" TV
I THINK IT GOT WET AND IT WONT COME ON AND THE GREEN LIGHT FLASHES THREE TIMES
MY TV WONT COME ON i THINK IT GOT WET, NOT SOAKED AND THE POWER LIGHT FLASHES THREE TIMES
    Novelist:
    Champion:
  • 236 Answers
You most likely got water in the high voltage circuits which caused an arc somewhere and burned the circuit board which caused a short. Stargazer
Posted on Aug 20, 2007
SOURCE:
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Power light blinks three times then nothing
A green LED that blinks On and Off is an indication on some models that the TV is receiving commands from a remote. By modelling, it just check SYN, SYN-ACK signal between transmitter and receiver. No worries.
Nov 23, 2013 | RCA F36650 36" TV
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sony tv won't turn on... When I hit the power it kicks in for seconds. the green light flashes four time then red flashes three times.
Tries unplug,replug tv back in an hour later,let the tv reset itself back to factory setting.The tv should work now.Not than the power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 15, 2010 | Sony Televison & Video
WS-55517 Mitsubishi Rear HDTV projection tv will not turn on
2 blinks followed by 1 blink is the X-Ray protection-----means some problem in the High voltage circuit ---set produces over 25 thousand volts to fire the 3 picture tubes inside up----It could be excessive high voltage-------I think you would have to get lucky for someone to find and fix it in your home----more likely it will need a visit to a Repair shop.
Aug 20, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Tv wont come on
Check the horizontal output and regulator transistors. If you ould like the service manual let me know I can post a link where you can purchase it and have it emailedto you along with free help to elp you diagnose and repair your set.
Feb 19, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
147 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
