Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
The control locked light will not go off. I have tried holding the end of cycle button for 30 seconds, unplugged the dryer and flipped the breaker still will not go off.
  • 14 more comments
  • Anonymous Nov 02, 2007
    Control locked. Cannot start machine. Unplugged for an hour.
  • anna kun Jan 08, 2008
    control locked light do not go out.and i can't stat washer
  • Anonymous Jan 10, 2008
    Control lock is on and I can't do anything. Model # GHW9460PL0
  • joeyl Jan 10, 2008
    Washing machine control is locked and I can't do anything. Model # GHW9460PL0
  • Tommy333 Jan 26, 2008
    Control locked light will not go out
  • waljohn Mar 30, 2008
    control lock light will not go off
  • Anonymous May 06, 2008
    holding the comtrol button and cycle wont start
  • HAZELLOU May 08, 2008
    CONTROL LOCK WON'T GO OUT AND I HAVE TRIED TO HOLD THE CANCEL BUTTON IN AND UNPLUGGED FOR FOR FIVE HOURS NOTHING HAPPENS. WHAT SHOULD I DO NEXT?
  • janie9045 May 14, 2008
    control light won't go off.
  • Anonymous May 19, 2008
    control lock light is on dryer and wont click off after holding cancel and control on and cancel button dryer wont turn on.
  • chickens2751 Jun 14, 2008
    whirlpool front load duet dryer is in control lock.
  • rxranch Jun 23, 2008
    I can't get the control lock light to go off. no response from the control buttons
  • duet3 Jun 23, 2008
    washer door is locked. light will not go out. door will not open. nothing changes it.
  • Anonymous Aug 17, 2008
    my control light is staying on will not shut off and can not start dryer
  • sdillabaugh Aug 26, 2008
    The control locked light will not go off. I have tried holding the end of cycle button for 30 seconds, unplugged the dryer and it will not go off
  • Anonymous Jan 21, 2009
    what is the answer?
Holding the End Cycle button for a few seconds worked! Yes
Posted on Jan 07, 2010
  • campbellsix Dec 03, 2010
    Thank you, thank you, thank you!!!!!!!!!!!!!! you saved my night and a very bummer call to Sears!!!!
  • jcislove7
    jcislove7 Jun 06, 2012
    Thanks so much, this really worked.
My Whirlpool Front Load Duet Dryer will not start. I only hear is a slight click when I hold down the start button. Any suggestions?
Posted on Oct 02, 2010
  • jreed_73059 May 08, 2012
    Belt is off or broken, likely
  • sarak Feb 16, 2013
    which belt? i was told the board went out which will cost 284.00
I have a whirlpool duet HT front loading dryer that makes a thumping noise @ high spin drying. Is there a troubleshooting solution? thanks
Posted on Sep 19, 2009
    Idler pulley going out
Press control,cancel and temperatura bottons at the same time.then press the end of cycle button.
Posted on Feb 03, 2011
3 seconds- end of cycle button
Posted on Apr 23, 2009
I just installed the Duet sport front load dryer I got a F-23 error message. Any suggestions?
Posted on Oct 22, 2009
  • Whirlpool Master
  • 19,396 Answers
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool.
The front light lit on my Whirlpool dryer...
Regards..
Posted on Feb 22, 2010
  • Ginko
    Ginko Feb 26, 2010
    Sorry, blind link.
    Here
    the article: My Whirlpool is control locked.
  • giovanna2013 Oct 14, 2012
    hello Ginko, I tried with your best and smart solution but It still not working for me .. another suggestion please I will be glad in advance.
After washes won't drain,  smells of foul odor, have to put it on drain and spin for it to empty
Posted on Oct 24, 2008
Worked so far hopefully nothing will go wrong or is not a sign of a bigger issue.
Posted on Jul 05, 2010
End of cycle button 10 seconds
Posted on Sep 25, 2008
  • 4txpalmers Aug 23, 2010
    This worked for me. Thank you! My husband is traveling tomorrow and we were very worried we would be spending our evening at the laundromat! Thank you!
GOD BLESS YOU FOR POSTING THIS!! IT WORKED!!
Posted on Nov 03, 2007
    New Friend:
I have a whirlpool duet dryer and I get a f-3 code any suggestions
Posted on Dec 17, 2013
Holding the End Cycle button for a few seconds worked for me too!!!!!
Posted on Jul 13, 2010
Yeap, 10 seconds worked for me...thank you.
Posted on Oct 29, 2008
Control On + Pause/lock + Temperature for 5 secs worked for me... GHW9400
Posted on Nov 07, 2007
THANKS IT WORKED A+++++++++++++++++++++++++++ TIM JUST HOLD 3 SEC
Posted on Nov 02, 2007
The above suggestion works. By the end of cycle button, it says to hold it for 3 seconds.
Posted on Sep 26, 2007
    New Friend:
I have a whirlpool duet front loader washer. I get a R H error. I can't delete or can not cancel my washer.. I took off the hoses to the washer and cleaned the filters out. Still won't work...Email dcomporato@yahoo.com
Any help appreciated
thanks
Posted on Jun 13, 2013
Yeah!!!! I just held the end of cyle button for a few seconds and the control locked light went off. thank you!!!!
Posted on May 20, 2011
Have 240 volt dryer will not go
Posted on Jul 09, 2010
End of cycle button worked for me....30 SEC
Posted on Aug 24, 2007
SOURCE:
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on on my whirlpool duet front load dryer and it won't do anything
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks
Nov 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer does not run. The control lock light stays on even after I hold down the end of cycle button for over 5 seconds and/or unplug dryer for over 15 min. The light comes on when door is...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load whirlpool duet washing machine controle locked light is on how to reset it?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&###%%
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
A whirlpool duet dryer continues with control locked light on...despite holding the cycle button down 3sec. no other buttons respond.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$#@
Feb 15, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet red light keeps blinking and wont start. it is not locked.I tried unplugging it and nothing works.
Nov 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet gas dryer has CONTROL light lit with malfunction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$#$#$
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet 2004 front load washers door is locked, time is flashing and pump is on. Unable to stop or open door. tried to unplug. Control lock is not on. My wife tried to add clothes when the add a...
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Elsewhere on this forum a fix was given that is rather easy. Someone in your home has activated the child safety switch. On the lower right hand side of the control panel, hold the bottom button in for 3 seconds until the light goes out.(safety control lock switch)
Nov 11, 2007 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
8,266 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
