Question about Samsung HP-R4252 42 in. Plasma HDTV
Convert 110 volts to 220 volts
I have a plasma Samsung 40 inches, and i need the conversion to 220 volts 50 Cycles. and I need too, the conversion from NTCSC to Pal N please, can someone to help me. thank you very much I am from Argentina, i hope this was write correctly and you can understand me. gracias
  • copesso Aug 20, 2007
    Thank you very much, i have a power supply 220/110, but anyway thank you a lot.
    Brigadier General:
  • 6,966 Answers
Hi, 1. To convert 110 to 220 - use a step down transformer between your mains and your unit with the watt rating equal to or greater than required by your unit; 2. If I got your brand/model right, I believe it is capable of either 50 or 60 Hz. However, if for some reason you still would want to convert convert 60 Hz to 50 Hz, it will be difficult and technically complicated. At best that I can offer is for you to get hold of an AC-DC-AC converter with the following specs input 220VAC/50Hz output 110/60Hz. 3. NTSC to Pal N would require complicated circuitry and if ever available would be expensive. Past experiences have shown me that any color conversion is not that satisfactory. It may be to your advantage to return the unit and have it replaced with a region correct model. Good luck and kind regards.
Posted on Aug 20, 2007
SOURCE:
Hello,I have Samsung TV UN40NU7100FXZA. It states 110 V AC, but when I opened it thee is an Power card BN44-00947A(it has a stamp pf 110-240 Ac 50-60 Hz). Can I use TV in 220 V Ac countries?
It should work fine on 220 volt if you get the right power cord..that means the TV can run on anything from 110 to 220 volt, its common with switching power boards to be this way
Sep 27, 2018 | Samsung Televison & Video
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
Samsung plasma tv
Power supply may have failed.
Aug 15, 2016 | Samsung 51 INCH PS-51D450 PLASMA...
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
Oct 07, 2015 | Canon F151300 LBP 3100 Mono Laser Printer...
I HAVE A PROBLEM WITH A POWER SUPLY OF SAMSUNG PLASMA PS 51 E530 ALL VOLTAGE IS OK,5VOLT 12 VOLT IS OK,BUT VS AND VA VOLTAGE 0VOLT SO NO SCREEN,I CHECK POWER ON AND VS ON IS OK,can you help me
Sounds like it could be a bad capacitor on the power supply, or possibly on the video out circuit. Bad capacitors are a common problem in Plasma and LCD monitors and T.V.'s.
Jun 25, 2014 | Samsung 51 INCH PS51E530 Full HD Plasma...
I need to convert power fro 220 to 110 volts
Mixer provides the facility to convert the power to another one.
In the mixer you will provided the key to convert 220 volt to 110 volt.
Drag that key to 110V.
Dec 23, 2010 | Kenwood KM800 Major Classic Stand Mixer
A 220 volt Amstrad monitor that i want to convert to use 110 volt
engagetek, This would be a very easy thing to do if and only if the label on the rear of the unit has printing similar to my GATEWAY LCD. It states as follows: "100 - 240VAC input 50/60hz." If your Amstrad unit's label reads "220-240VAC 50/60hz only, then you will need to reverse engineer the "ac to dc" power supply, be it an old "linear" or a modern "switch-mode-power-supply" type. You did not state what type of monitor technology your Amstrad is. CRT, LCD, Plasma,???? I would guess that it is a CRT type. Well anyway, I hope the info was of some use. Bye for now, I'm louie12fix on fixya
Oct 11, 2009 | Computers & Internet
Samsung HP-R4252 42 in. Plasma HDTV Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
