Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Step-by-step instructions for tuning TCP under Windows XPsp2
Do you know the best route for this
    Scholar:
  • 76 Answers
Although SilverDragon was more than kind to provide a couple links, my years of experience in tweaking all TCP registry entries has not increased the speed of intra or internet communication. XP SP2 automatically sets up a very good TCP handshake with external devices. A good place for TCP modification usage would be to scale DOWN the settings to match slower or difficult connections. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 21, 2007
  • Microsoft Master
  • 12,061 Answers
Here ya go.... a couple of links for you.. www.psc.edu/networking/projects/tcptune/OStune/winxp/winxp_stepbystep.html www-didc.lbl.gov/TCP-tuning/Windows.html
Posted on Aug 20, 2007
SOURCE:
Explorer cannot find d link, was working for a long time then quit, then working, now not working
Improve the Fixya.com experience for everyone by voting!
Unfortunately, you haven't provided any details as to the steps you've thus far taken. So lets start at the beginning and solve your problem step-by-step.
Step 1 Locate the Queue name, or Port name, of your printer.
Click here for instructions on locating the Queue name since you are using a DPR-1260.
Step 2 After you locate the Queue or Port name, you will want to write it down. (You can also highlight it with your cursor, and copy the info. This will allow you to paste it in to the wizard later on.)
Step 3 Click Start and then Control Panel. Locate the Printers icon. Click the Add A Printer icon.
Step 4 Click Add a Local Printer. Use this option only if you don't have a USB printer. (Windows automatically installs USB printers when you plug them in).
Step 5 Select Create New Port. For the port type, select standard TCP/IP Port. Click Next.
Step 6 Click the drop down menu for Device Type and choose TCP/IP Device.
In the Hostname or IP Address field, input the ip address of your print server. (The default address for most of D-Link's print servers is 192.168.0.10).
The PORT NAME field is purely for identification purposes. This allows you to discern the port you've created later on for configuration.
Step 7 Windows will attempt to detect the printer. Please allow a few moments for the operating system to do this.
Step 8 Highlight the radio button labeled Custom and press the Settings button.
Step 9 Click the radio button labeled LPR.
The LPR Queue Name field will now become available. Here you will need to enter the Queue or Port name that you acquired in Step 1.
Check the box labeled LPR Byte Counting Enabled. Click OK.
Step 10 At this point, you'll be brought back to the previous window. Click Next.
Step 11 Windows will now attempt to detect and install the printer driver. If Windows is unable to detect the printer and find a matching driver, you will be given the option of selecting a printer from a list of available printer drivers.
Step 12 In the left window you have a list of manufacturers, and on the right side you have the various models. Select the model that pertains to your printer. Click Next.
Step 13 Next you will be prompted to give the printer a name. You can leave the default Windows name, or you can create your own if you wish. Click Next.
Step 14 Once the printer successfully installs you will be given the option to print a test page. If the test prints then the print server is configured properly. Click Finish.
You should be linked up now.
All the best
Ben
Jul 11, 2011 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Wireless connection very slow
Lets fix that
How To See Current Auto Tuning Settings
1. Open a
elevated command prompt.
2. Click on Continue in the UAC prompt.
3. In the command prompt, type in bold belowand press Enter. (See screenshot below)
netsh interface tcp show global
4. Close the command prompt when done.
5. Run through the steps below to see if you have a TCP/IP Auto Tuning issue
STEP ONE
How to Restrict Auto Tuning
1. Open a
3. To Restrict Auto Tuning
NOTE: Allows for the receive window to grow beyond the default value of 65,535 bytes, but limits such growth in some scenarios.
A) In command prompt, type in bold below and press Enter. (See screenshot below)
netsh interface tcp set global autotuninglevel=restricted
B) You will get a OK response if successful. If not, repeat step 3A.
C) Go to step 5.
4. To Highly Restrict Auto Tuning
NOTE: Allows for the receive window to grow beyond the default value of 65,535 bytes, but doing so very conservatively. In this mode, Vista will by default use a RWIN of 16,384 bytes with a scale factor of 2.
A) In the command prompt, type in bold below and press Enter. (See screenshot below)
netsh interface tcp set global autotuninglevel=high
B) You will get a OK response if successful. If not, repeat step 4A.
5. Close the command prompt window and restart the computer to apply the changes.
6. If it fixed your problem stop here. If not, continue to Step Two below.
STEP TWO
How to Disable Auto Tuning
NOTE: Disables the autotunning feature in Vista completely, and sets and locks the RWIN receive window to the default value as 65536 bytes.
1. Open a
netsh interface tcp set global autotuninglevel=disabled
image4.gifNote
You can also type in bold below and press enter after each command:
netsh
interface
tcp
set heuristics disabled
exit
4. You will get a OK response. If not, repeat step 3.
5. Close the command prompt and restart the computer to apply the changes.
6. If it fixed your problem stop here. If not, you may not have a issue with Auto Tuning and will need to turn it back on. Continue to Step 3 below.
STEP THREE
How to Enable Auto Tuning Back to Normal Default
NOTE: This turns Auto Tuning back to the default on (Normal) setting in Vista. Allows for the receive window to grow to accommodate almost all scenarios. See NOTE at the top of the tutorial for more on this.
1. Open a
3. In the command prompt, type in bold below and press Enter. (See screenshot below)
netsh interface tcp set global autotuninglevel=normal
image4.gifNote
netsh
interface
tcp
set heuristics enabled
exit
4. You will get a OK response if successful. If not, repeat step 3.
That's it,
Hit me back for more tweaks
Jan 29, 2011 | Computers & Internet
I beleive my router may need to be configured to allow APPLE tV to communicate with my computer. I can access the router and download from internet with Apple TV. I cannot perform home sharing with...
NAT STRICT
Step 1 : Connect Router - Computer ( Wired )
Step 2 : Open Router setup by typing http://192.168.0.1 on the address bar of the internet explorer
Step 3 : The Default Password is admin
Step 4 : At the top Click Advanced
Step 5 : On the left Click Firewall Settings
Step 6 : Enable DMZ
Step 7 : give the IP Address of the Computer in it
Step 8 : Uncheck the option Enable SPI
Step 9 : Click Save Settings
Step 10 : Test the connection
let me know if this works
Regards
TOM
Dec 27, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I am not able to connect to the internet using my Linksys WRT54G V8. When I connect the cable directly to my laptop, I am able to access the internet, so it is definitely a problem with the wireless...
Title: Setting-Up a Wired Computer to Obtain an IP Address Automatically Article ID: 4033
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
Please connect me to Pulkit558
Hi Sir,
I guess you chose a wrong option. This is not Chat but let me give you the instructions on how to get your prints working on both macs.
First of all check the ip address of the mac. Check it on both macs. To do that follow the instructions below.
Step 1. Click the Apple logo on the top left of the screen.
Step 2 Select "System Preferences".
Step 3. Select "Network" under the "Internet and Network" section.
Step 4 Select which connection you'd like to check in the "Show" drop-down menu. If you're hooked up via ethernet, select "Built In Ethernet". If you have a wireless network, select "AirPort".
Step 5 Select "TCP/IP" on the "Network" screen.
Step 6 View your computer's IP address on the subsequent screen displayed on your Mac.
Now you know the ip address of your mac.
Now we have to ping the ip address and have to check if there is connectivity between macs. Follow the instuction below to check that :
Step 1. On Finder in the dock.
Step 2 Click on Macintosh HD in the window.
Step 3 Click on Applications.
Step 4 Click on Utilities.
Step 5 Double-click on Network Utility.
Step 6 In the Network Utility window, click on the Ping tab.
Step 7 In the field under "Please enter the network address to ping"(enter the ip adress of other computer)
Step 8 Click the Ping button.
Try theses steps first and check if they have connection.
Mar 27, 2010 | Computers & Internet
How do I change my I.P. addess...I'm having compatibility problems with my wireless router and cant get on line
1.
Control Panel
Network Connections
Wireless Connection
Properties
Make sure Internet Protocol TCP/IP is set to "Obtain an IP address automatically"
2.
Start/Run
CMD<enter>
ipconfig /release<enter>
ipconfig /renew<enter>
Nov 27, 2009 | Compaq Presario 700 470024-192 Notebook
TCP/IP Stack Repair
try
open a command prompt, click Start and then click Run. Copy and paste (or type) the following command in the Open box and then press ENTER: cmd 2. At the command prompt, copy and paste (or type) the following command and then press ENTER: netsh int ip reset c:\resetlog.txt
Sep 30, 2008 | HP Pavilion a340n (DQ099AABA) PC Desktop
D-LINK DP301U
TCP/IP printing for windows xp:
you must know the IP address of the print server and the port name.and the pc's ip address must be in the same subnet as the print sever's ip address.
Step 1 Go to Start > Settings > Printers and double-click the Add Printer icon to open the Add Printer Wizard.
Step 2 Select Local Printer and click Next.
Step 3 Select Create a New Port and choose Standard TCP/IP Port from the drop-down menu and click Next.
Step 4 This will bring up the Add Standard TCP/IP Printer Port Wizard. Click Next.
Step 5 Enter the IP address of the print server and the port name and click Next.
Step 6 The next window will prompt you for the Device Type. Select the Standard radio button and use Generic Network Card from the drop-down window.
Step 7 Click Finish to close the port configuration wizard.
Step 8 This will bring you back to the Add Printer Wizard. Step through the remaining windows of the Add Printer Wizard, accepting the default values to complete configuration.
May 29, 2008 | D-Link DP 301U (DP-301U) Print Server
WINDOWS VISTA - CAN'T SET UP LAN: SOFTWARE NOT COMPATIBLE?
I don't see Vista listed in the SBG Manual, but they do list several windowS OS versions. Looking at Windows 2000 for an example, you basically need to go into the control panel and make sure TCP/IP is configured correctly.
If Internet Protocol (TCP/IP) is in the list of components, TCP/IP is installed. You can skip to step 10.
If Internet Protocol (TCP/IP) is not in the list, click Install. The Select Network Component Type window is
displayed:
In both cases, the box next to Internet Protocol (TCP/IP) needs to be selected.
If you need the steps in selecting the network component type let me know and I'll try to post those steps also.
Mar 03, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Recovery cd
Hi, try this
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
It may not be exactly what you are looking for but there are many other downloads on the microsoft website that my be able to help you with your recovery disk.
Hope this helps,
Owain
Feb 23, 2008 | Maxtor Hard Drive
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
