Question about Hitachi 43FDX15B 43" Rear Projection Television
Power light stay on
The red power light stay on when tv is off and tv works fine that I know of.
    Sergeant:
  • 308 Answers
Sounds like you may have a sticking Relay S901 on the power board. Tapping the Relay may Make The Light Go On And Off. The relay part number is FJ00142 if you can find someone to work on the set for you as it would involve soldering in the new part. The number on the relay may be ALKS329 with the former part number being the Hitachi Part number.
Posted on Aug 20, 2007
SOURCE:
Panasonic TV TH-L37S25A no power no red light, when plugged in and turned on at wall.
I'm guessing your power board went out and will need replacing. If you have the model number correct your going to have a hard time finding that board, I looked and couldn't find one anywhere, couldn't find that model listed
Feb 09, 2018 | Panasonic Televison & Video
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
It will power on but then turn right back off it worked fine yesterday
One of four things happen when these lcd's get power problems. 1. They either go completely dead[no power with no lights] 2. Little green light will blink and go back to red with dtv briefly showing and then the tv screen go blank 3. Same as # 2, but with screen staying blank. The fourth is extremely rare, which is a shorted panel that makes the tv set behave like it's getting no power. All signal a bad tv, and the fourth is not usually repairable, requiring a whole new panel. I hear that power flows thru the panel, so that would explain how sometimes it will short out.
Apr 28, 2009 | Emerson EWL3706 37 in. LCD Television
Red Power Light Stays on
Hi, you have a leaky diode, it will not hurt your tv it`s just annoying, my Hitachi has done the same thing for a year and I`m just too lazy to change it out, video-tek
Feb 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Problem
with my projection tv , i have a Mitsubishi dlp, the screen went black and a red light flashed it was the bulb that had to replaced i dont know if that maybe your problem.
Aug 20, 2008 | Toshiba TZ50V61 50" Rear Projection...
Insignia lcd tv 32"
have good tec replace if nessary, The inverter module
Mar 03, 2007 | Insignia IS-LCDTV32 32 in. Television
Hitachi 43FDX15B 43" Rear Projection Television Logo
83 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
