I need to know how to replace the rear driver turn signal bulb. I have the bulb and grease. What do I do with the grease?
Well if you open your trunk and look at the drivers side there should be a little door with a screw and if you open it theres a little casing with two pull tabs scwezz and open put a little grease on the plug end of the bulb and insert then reasemble
Remove the tail light, might require the removal of inside panels. The grease is for the electrical connection. The metal end of the bulb
Thanks guys. I thought that might be what the grease is for but I wanted to make sure.
left rear turn signal bulb out
