Question about Canon Elura 60 Mini DV Digital Camcorder
Zooming problem my canon elura 60 is at max zoom and it can not restore.
  • 6 more comments
  • Rlhulk Jan 01, 2008
    I have the same problem and do not have a solution. You would think that Canon would let all know what the problem is so that we can make an informed decision on whether to get it repaired or find another camera!
  • SMSturbo Mar 02, 2008
    I am having the same problem with my Canon Elura 60. It started zooming by itself today. I can't stop it. Any suggestions are appreciated.
  • Anonymous Mar 20, 2008
    The school that I work at has two of these cameras. BOTH started the "autozoom" problem.
    I would recommend against buying this camera.
  • Anonymous May 04, 2008
    Yup, Me too. Was going to pop up to the Canon repair shop, but was looking online to see if there was a simple fix. Will pass on the world wide frustration !
  • Guest121 May 06, 2008
    I bought Elura60 mid 2004 and worked normally for 3 years. Since last year, it came up the "zoom-by-its-own" problem. So far there is not solution to fix. Sometimes, it heals by its own. But most of times, It has zoom problem. I have to hold the zoom button all the time when I record.
    It seems that all Elura family (60, 65, 70 and ...) has this problem.
    Starting class action is one way to go if we can not find a good solution for this problem.
  • Anonymous May 13, 2008
    I have two 70s that I bought at the same time and within a week of each other started doing the "auto zoom".
  • oliverbyrne Dec 25, 2008
    I have the 70 model, how do you start a class action, what a piece of shight. I also owned a canon powershot, around the same time the zoom issue, the powershot decided to take pictures in only orange. Only solution, pay Canon another $100+. I'm sure it would be the same for the Elura 70. Built in breaks to keep you paying. All firmware/software issues worth $$.
    How do we get these guys to fix their bugs without charging us? simple download off of the web I bet.
  • bigred42 Jan 12, 2009
    I have the same problem, Canon Elura 60 with "phantom zoom" - Contacted Canon, they said too bad.
    Suffice it to say I won't buy Canon again.
Whacking the camcorder did fix this problem. Search posts in Elura 70.
Posted on Dec 04, 2008
I have the same problem. I have no fix in rec mode but if it happens during playback; press menu and select the zoom options. You don't have to pick any but just keep the menu displayed on the screen. I do this while recording the tape to my DVD recorder and it solves the locked zoom problem. The menu display does not get recorded.
This zoom problem is a big pain. We should start a class action suit against Canon. It started within a year of ownership with mine. I bought a Panasonic recently and haven't looked back.
Panasonic doesn't have the slick Canon marketing/packaging but it is a much better machine.
Posted on Mar 11, 2008
SOURCE:
My canon elura 60 when open my video cam it zoom automatically and the zoom lever dont work.
The zoom assembly will need to be replaced. This repair should be done by an experienced technician. Unfortunately, there is no easy fix that you can do yourself.
Hope this helps you.
www.austintelstarservices.com
Jul 21, 2011 | Canon Elura 60 Mini DV Digital Camcorder
My canon elura 60 digital video camcorder doesn't zoom in and out. it seems to be stuck
Sometimes a smack around the edge of the lens will work. If it doesn't, then it might be a motor issue and will need to be taken apart.
Nov 12, 2010 | Canon Elura 60 Mini DV Digital Camcorder
Our Canon Elura 65 Camcorder won't focus. The
First off I don't condone or advise hitting an electronic device but, from the advice of another post I did it and it worked. It shouldn't have but it did. I hit the bottom of the camcorder with the palm of my hand and it worked perfectly afterward.
Jun 28, 2010 | Canon Elura 65 Mini DV Digital Camcorder
Elura 60 doesn't take still pictures
I had a similar problem with zoom being stuck and also not being able to take a still. I tried the suggestion of whacking it in the area of the zoom and photo button and it started working.
I just tapped it with two fingers. Sounds odd but it worked. good luck
Sue
Jun 04, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Zoom button is malfunctioning
tons of people w/ any canon elura series cameras including myself, with a canon elura 80 have the same zoom problem. It does not appear that canon has done anything to try to solve this mass problem with this series of cameras. Oddly enough the only way to solve this problem is to give it a tap and gentle hits near the zoom button to release what would seem to be a jam. Sorry that there's really no straight forward answer, but for now its the best i can give.
May 03, 2008 | Canon Elura 80 Mini DV Digital Camcorder
Canon elura 65
on mine the ribbon cable from the button to the main board was pinched by the door and shorted
Feb 13, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon elura 60 camcorder zoom is at its maximum and it is stuck .
 I have the same probelm how can i fix this.
Oct 15, 2007 | Video Cameras
Canon Elura 60 - Zoom is on maximum and won't restore. I own Canon Elura 60 since last two years and now i'm facing problems with zoom. Zoom button does go to and fro but actual zoom doesn't take...
Hi There, did you find any resolution for this problem? If you could share any info about the problem, it will be really great. Even I have the same issue with my Elura 70. Thanks.. Pradeep
Nov 08, 2006 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60 Mini DV Digital Camcorder Logo
298 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
