Question about Maytag DWU9962 Dishwasher
Bottom Washer Arm Problem
The bottom washer arm stops turning and is very stiff when turned manually. We've taken it apart and cleaned out the inside, this works but it is happening all the time. If we don't wash our dishes before putting them in the dishwasher. We never used to have to do this. Is there a part (food grinding/clearing) that we need to replace? Thanks for any help you can give!
  • 51 Answers
Hi Karen P The bottom arm ( well all arms really)is rotated by the water pressure created by the main pump. The bottom arm should spin freely when rotated by hand. If not, then the bush (or plastic bearing) may be worn or sticking. These parts are fairly inexpensive (at worst a new bottom arm will be required). Contact your local Maytag spares supplier and ask for a Bush repair kit for the bottom arm of your model. Regards
Posted on Aug 20, 2007
SOURCE:
lift the arm off there should be a washer that the arm sits on,that washer may be missing or worn out.when you have the arm in your hand do you see bearings?if not try to find a washer the diameter of the arm and install it before you put the arm back on.
Aug 19, 2007 | Maytag DWU9962 Dishwasher
Top arm stopped rotating on Bosch clasixx
not worth fixing, you are better off putting that money towards a new one. unless you can find the arm and repair it yourself
Nov 10, 2011 | Bosch 24 in. SGS43C12 Classixx...
GE Dish Washer GSD 2800 DO3 runs a partial cycle...(even empty) and then beep and gives a message on control panel "washer arm blocked". Even ran without dish rack in washer still got the...
the rotating arm has a magnet in it to let the controls know if it is turning. Yours is not turning so
  • check the jets for blockages... you might have to remove the arm to clean them properly
  • make sure there in nothing stopping the arm from turning...spin the arm manually to see if it rotates freely.
  • knives etc sticking upward can stop the arms from rotating on the top rack
  • if you run without the rack the arm will obviously be not telling the electronic it is not blocked because it is not there. the rack must be in the machine with the magnet and the magnet passing correct messages.
  • If there is really no blockage then there is a elect fault that need to be sorted professionally.
  • PS have you taken the arm off anf squirted a hose up the inlet to see if water comes out all of the jets????
Mar 01, 2011 | Dishwashers
The washer smells bad. We have taken it apart and cleaned between the tubs. The agitator turns in both directions
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 21, 2010 | Whirlpool LSQ9659PW 2 SPD 10 CYC 4 TEMP 5...
Bottom of my Bosch dishwasher not cleaning dishes, top tray OK have cleaned / taken apart
Carefully inspect the lower spray arm for a crack or separation.
Also inspect the holes in the spray arm that may be stopped up with debris.
Remove and clean the filter in the front center of the tub.
Set the spray arm at the 12 o'clock position and start the washer. After 30 seconds open the door and check the position of the spray arm. Do thi several times to confirm the spray arm is rotating.
Feb 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a Bosch Dsihwasher - model SGS53A. The lower washer rota arm is not turning. I have checked that water outlets are not blocked in the arm - all clear. The up arm turn normally. Steve
arms rotate by water volune and pressure / ck to see if the screen in bottom and the cup sreeen is clean . if not clean it with a stiff nylon brush reinstall and try it again // also ck water level if too low this would cause problem .. float or pressure sw causes low water . or water valve filter screens .. hope this helps let me know .. **** .
Dec 04, 2009 | Washing Machines
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Does the draw compartment come out inside
Remove any parts that you can in the drawer itself ,and thoroughly clean all pieces., and poke wire through syphon tube, to make sure it is clear.
In the drawer compartment get a stiff nylon brush and clean all the inside out as best you can, particularly the top of the compartment.
Plz rate my solution.
Thanks.
Jan 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Top rack arm doesn't spin.
matt, did you get down to the chopper screen? If that screen is clogged the flow to the upper arm will be restricted. Check out the pic, Catriver
Sep 29, 2007 | Kenmore 24 in. 17362 / 17364 / 17369...
Dishwashers Logo
157 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
