Question about Kenwood KAC-X501F Car Audio Amplifier
Kole Audio Amp does to protect when I turn it on
My Kole audio amp goes to protect mode when I turn it on. Everything is wired correctly but I suspect the ground connection might be the issue
    Brigadier General:
  • 6,966 Answers
Hi, Assuming you have been using the unit already for some time, it is possible that: 1. (Agree with you) The ground might have loosen up, re tighten the connection points and make sure that if it is chassis/body grounded, there is no paint/corrosion between the grounding lug and the point of connection. Better still,wire at least a #14 autowire from the amp's body to the negative of your battery; 2. check and verify that the speakers connected to the amp are good; 3. The speaker wirings might be touching the car's chassis or grounded somewhere. Check where the speaker wires pass and leads to visually making sure that no bare/scraped wire touched any metal part of the car; and/or 4. The amp itself might be at fault and would require the services of a qualified professional. Hope this gives you some ideas and work out for you. Good luck and pls post back how things are and/or if you need further information. Kind regards.
Posted on Aug 20, 2007
My kole audio amp protects when powered
you read amp catalogue there written it briefly.
Mar 27, 2013 | Kole audio Nitric XP4-1000 Car Amp
The light is red and no bass is coming out of my subs
The Amp Is Most Likely In Protection Mode... 2 Ways To Figure Out Whats Wrong With it Is Check Every Single Wire And Make Sure That Every thing Is Hooked Up Correct And There Are No Bad Connections With Ur Remote Wire, Ground Wire, And Battery 12v Wire, Rca Cables As Well. If Every Thing Checks Out Good Then Try Checking The Fuses And Make Sure u Are Using The Correct Fuses That Are Good For That Amp. If U try These 2 Things And You No Your Subs Are Hooked Up Correctly Then The Worst Is Probably There. I Had The Pioneer 7200 Amp And It was A Blown Amp And The Red Light was Constantly On. No Sound No Nothing. If U Try Those Steps And it Still Does Not Work Then Most likely Your Amplifier Is Toast. Hope This Helps :-)
Feb 18, 2011 | Kole audio Q2-1920 Car Audio Amplifier
How do i get my Kole audio qx4-720 amp out of protection mode
be sure the master volume is in minimum some amplifier has protect circuit when the volume exceed the maximum sound level to protect circuits from damage. try to disconnect speakers maybe one of them are shorted already
Feb 02, 2011 | Kole audio QX4720 Car Audio Amplifier
My Kole qx1-30000 ground wire gets hot and no sound out of RCA and amp goes into protect mode. Why does this happen?
make sure that the fuse under the hood is the right amp and that your ground is secure and solid
Mar 30, 2010 | Kole audio QX1-2400D Car Audio Amplifier
Protect comes on then turns back off,one of my three fuses is not getting power
May 22, 2009 | Kole audio Q2-980 Car Audio Amplifier
Kole amp in protect mode?
Are you setting the bridge switch for both left and right or are you trying to run both subs off of one set of terminals? If you running the subs off one set of terminals you are effectively running the amp below 2ohms and thus the amp is not 2ohm stable and you will destroy it.
Some amps actually all ready run a bridged output for left/right operation, this could also be the reason why the protection circuit is kicking on.
Either way it's a component mismatch and you either need a stronger amp or different subwoofer setup.
Mar 09, 2009 | Kole audio Nitric XP2-2000 Car Amp
Kole kx2-1440 wiring da amp up right
It is correct to connect the amp turn on wire to the amplifier remote. 5V is sufficient to turn most amplifiers on... It should be 12V optimally.
If the amplifier is not turning on with the ant. remote, the problem is with the amplifier.
Dec 30, 2008 | Kole audio QX1-2400D Car Audio Amplifier
Protect light will not turn off!?
In most cases when the protect light is lit, the amplifier's output transistors have failed.
If the amplifier goes into protect with no speaker wires connected to it, it's likely in need of repair.
Nov 26, 2007 | Kole audio QX1-2400D Car Audio Amplifier
Kole audio q1-3000d
This amp is similar to many of the planet audio class D amplifiers. These amplifiers have quite a few problems. If the amplifier has failed, it needs to be serviced by someone who is familiar with the amplifier.
Do not repeatedly replace the fuses. It will lead to more damage and a more expensive repair.
Nov 12, 2007 | Kole audio Q1-3000D Car Audio Amplifier
Kenwood KAC-X501F Car Audio Amplifier Logo
73 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
