Question about Panasonic DMR-ES25 DVD Recorder
Self-Check Problem Every time I turn the machine on it displays error message U61 and then displays a message stating that the self check has failed and gives you two prompts. One to hit enter and it will power off or to press return and it will power off and try to correct itself. However, when I power the machine back up the same sequence occurs. It is a continuous loop and I cannot figure out how to correct the problem.
  • 8 more comments
  • Anonymous Nov 08, 2007
    I have the same problem. Tech support said I'd have to take it in for repairs (and that I'd have to prove it's under warranty, because registering with them doesn't actually do anything).
  • Anonymous Jan 04, 2008
    I also just started to get the U61 followed by a failed self check. All you can do is power it off and on and it repeats the issue. Of course mine is now 13 months old. I did just open a new stack of DVD-R and put the first one in it before it happened. On another site a guy took it apart and cleaned it thinking something holding onto the disk was slipping. I may gibe that a try.
  • ecnef Jan 10, 2008
    My machine started doing the same thing.
    Ive had it for about 2 years. It started with the U61 error after
    using trying to finalize on Sony DVD +R disks. The first time I had
    used these disks.
  • myprob2 Apr 02, 2008
    Yesterday while recording a show, the U61 message showed up. Has anyone got an answer from someone that fixed this problem? Of course our warranty ran out in February of this year.
  • Lisa mazon Apr 21, 2008
    Have exactly the same problem. U61 error and when I follow the on screen instructions it does not correct anything except puts me into the loop of repeating the same steps as already described in here. Took us an hour to figure out how to get the disc out since it didn't eject on it's own by pressing the stop button and ch up button at the same time for 5 to 7 seconds. But now the tray sticks is out in the "unit off" position.
    It's interesting that the manual troubleshooting guide says "wait for the message to disappear ...the unit is not broke"...yeah right.....why does it need repair then?
    My unit is only 6 months old and the night before my DMR-ES15 gave out also after only one year. This one won't recognize any discs.
  • Anonymous Jun 12, 2008
    I am having exactly the same problem as others have described. Is there any way of resetting to default factory settings?
  • vagle013 Jul 02, 2008
    I am getting a u61 message on my display
  • Devlinski Jul 07, 2008
    You say something about three screws, but where are they, how do I get at them, do I remove the top or what?
  • privatepilot Sep 12, 2008
    U61 code i have the same continuous repeating problem also as described above and it's driving me crazy.
  • schuko Feb 04, 2009
    I have the same problem. My recorder has gone into a loop of failed self-check and I can't use it. Just prior to this, the Flexible Recording stopped working, and then it stopped reading DVD-RW discs.
U61 ERROE MINS
Posted on Apr 19, 2008
SOURCE:
I have a Panasonic DMR-EZ47VEB and after recording overnight next morning dicovered the machine had swiched off with the word"Hello" on the front display. When switched on the unit displayed the...
U61 is a common fault in the Panasonic DVD recorders. It is generally a failure of the DVD-RAM drive and/or the digital controller board (in some cases it is both and both must be replaced together as a module). Unfortunately these are not repairable at individual component level; they would most likely need to be replaced and fitted by a qualified technician in an authorised Panasonic service centre. The only trouble here is the potential cost(s) involved (such as labour, the DVD drive, etc) - could be expensive and/or uneconomical. However, you can always submit your unit to a repair shop for a quote and a second opinion (on the costs of the replacement part(s) as well as estimated labour charges and the extent of the problem - this allows you to make an informed decision afterwards to get this fixed, but it is up to you.
The cost of a new DVD-RAM drive (if that is the actual problem, and not the board it is connected to) is quite high; anywhere between $130 US (for XVY1961 to suit DMR-ES35V/DMR-EZ47V models) up to $450 AU for the same device plus labour costs should you choose to have it replaced.
I assume you like your unit and want it working properly. If you do decide to deal with an authorised Panasonic service centre, ensure that when the work is completed they provide a detailed report, and some sort of warranty on that repair, especially if it involved replacing the DVD drive. Unless you have an extended manufacturer's warranty on this; which means it won't cost you anything to have it assessed and repaired fully.
Apr 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Unable to clean message
If you look at the Brother website you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the printhead is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck piece of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Aug 16, 2010 | Brother MFC-5840CN All-In-One InkJet...
Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
Nov 20, 2009 | Panasonic DMR-E55 DVD Recorder
Unable to clean
If you look at the Brother website, you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the print head is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck peice of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code soemwhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Nov 12, 2009 | Brother MFC-440CN InkJet Printer
Panasonic DMR-EZ47VEB stuck on self check
Check IC in primairy power supply
Aug 29, 2009 | Televison & Video
U61 Code will not reset - any suggestions?
You have the same issue as the one who is posted here at Fixya. But this requires you to open the DVD cover. If the unit is still under warranty, its best to bring it to the authorized service center. If not, you can try and test this if it'll work.
http://www.fixya.com/support/t221217-u61_error_code
"I have the same problem (same error # same model of DVR).
I noticed it happened after I left a DVD in play mode and paused for a long time.
I saw a message on the Internet that error U61 can mean that the lens is unable to move (return to its normal position).
The Internet message said that person unpluged everything, then opened the cover to the DMR-ES15 (3 screws) and gently pushed the DVD head back towards the rear of the DMR-ES15.
I assume that would void his warranty, but I am considering trying it since the time to have it repaired versus the replacement cost makes the possibility of a "self-repair" attractive.
Here is part of that actual Internet message. I hope it helps you:
Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept re-booting with the error U61. I noticed that the drive was making some noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more U61 error.
I test the unit this morning again and everything seems to work properly again!"
Aug 17, 2009 | Panasonic DMRES15 DVD Recorder
U61 ?
Sounds like ya got big problems as it's the mother board in the tv that has carked itself, gunna cost more fer a new board than for a new tv. Best git down to the store and git yerself a new one for xmas.
Nov 17, 2017 | Panasonic DMR-ES46VS DVD Recorder/VCR
U61 error code
UMM the DVD top lid uses FOUR screws. The entire DVD drive is bolted to the chassis with 3 screws.
Oct 14, 2007 | Televison & Video
Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES25 DVD Recorder Logo
1,020 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
