Question about GE RM24912 Universal Remote Control
Sleep timer will not work
Although a few of the codes work ok with my toshiba tv, the sleep timer simply will not work.
  • Anonymous Feb 24, 2009
    Same problem with my Magnavox tv.
  • Anonymous Feb 27, 2009
    I bought a universal remote for my orion tv and all the codes work but none of them will get the sleep timer to work?
The sleep does not work at all on this remote it is like some kind of recall
Posted on Mar 27, 2008
SOURCE:
TV turns itself off?
I am sharing four cases in which your tv either turns itself off or appears to turn itself off.
TV appears to be off
  • You using your tv as a monitor or your pc is in sleeping mode.
  • Your cable or satellite Box is not outputting a signal.
TV turns iteself off
  • The sleep timer is set.
  • The off timer is set.
Your tv appears to be off:
If you are using the tv as a monitor If you are using tv as a monitor and the stand-by light only
blinks for a few seconds when you press the power button,your pc is in the sleeping mode. To take your pc out of sleep,press a key from your key board or move the mouse.Tv turns on.
If you are using TV with a cable or satellite Box
If you have a cable or satellite Box your Tv may appear be off because the cable or satellite Box is not outputting a signal.Press the guide or info button on the cable or satellite Box remote control.
if the screen displays info or guide data,the problem is caused by the Box,you must call your cable provider.
if screen does not display info data,change the source on your TV.
Nov 14, 2014 | Televison & Video
Toshiba 20vl14 power loss
problem with power supply ask technician check it...
May 04, 2008 | Toshiba 20VL14 20 in. EDTV-Ready LCD...
How do you set the timer on remote
Hi, you do not set the sleep timer on the remote. You set it on the TV. In order to do this with the 076B0MQ051 REMOTE you must simply press the SLEEP button.
Oct 31, 2013 | Sharp 076b0mq051 Remote Control
Sleep-timer grundig p37-060
i need the code of sleep timer on gruding tv please
May 04, 2012 | Televison & Video
My tv turns off after about 10 mins and sometimes a few hours for know reason
Ok not sure if this is your problem, BUT, I have done this before! If you hit the SLEEP button on your TV's Remote control you may be setting the SLEEP TIMER on your TV. It is made so you can watch a show and fall asleep on your couch and the TV will shut off after a specified time. On mine it is anywhere from 30 minutes to 3 HOURS! My remote says the word SLEEP over the timer button. not sure on yours
Hope that solves the problem, just hit the button until the word "OFF" shows on your screen.
Feb 27, 2011 | Televison & Video
How do I use the sleep timer? when I push the sleep timer button it gives me on time and off time to set. I dont know how to use this. Cant I just set sleep timer for 30 minutes to turn off? Thank you.
Hello
Before going to set the timer, you have to set the current time. Set it according to the manual with you. If the timer function work properly, there must be an uninerrupted power supply also. If the power goes off, the set time will also get resetted, and improper function will occur.
After setting the present time, set the "on" time and "Off" time. The TV will switch on at that time you set, and will switch off automatically after the end time. OK.
Dec 23, 2010 | RCA 20F420T 20" TV
Timer
firstly check your sleeping timer set ups. if that is okey, then check the following
the power supply components eg
power transistor on the power supply lekage
zener diodes, power diodes of the bridge rectifier.
in short the supply is drowing to much current, hence semiconductors are heating up and reach a cutoff point, and saturates
Mar 29, 2009 | Toshiba 35A44 35" TV
Sleep light
i have a simular problem with my sony kvfs120 32, my stand by timer is flashing and the tv will do nothing else. the flasing light is actually a self diagonistic code mine is flasing 5 times.
Ray
May 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Where is the sleep timer????
just checked a similar sets owners manual...the sleep timer on this model is located in the menu---setup,,this menu prompt has language,SLEEP,menu trans,menu timeout ,and default setting....if you don't see the SLEEP mode in setup--you probably don't have it!...hope that helps
Aug 20, 2007 | Initial DTV-322 32 in. TV/DVD Combo
Televison & Video Logo
452 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
