Question about Samsung MS1040BB Microwave Oven
Oven won't work
Power is on , displays a number 8 and will not function
  • 1 more comment
  • Anonymous Nov 02, 2007
    My microwave oven appears to run normally but does not heat anything up. I was told it may be the magathon. Can this be easily replace and can I attempt this myself. Thanks
  • Anonymous Dec 12, 2007
    9 is the only number that works. It will beep every once and a while. It will not turn on.
  • kansal_p Aug 31, 2008
    Built-in GE Micorwave, model# JE1860BH04. 1 year old microwave has power but the fan does not work and it doesn't heat food or water. Light turns on inside and after setting the time, countdown begins but no sound.
My kenmore microhood won't come on when you start it
it will flip the breaker
Posted on Jul 31, 2008
  • Samsung Master
  • 9,174 Answers
I would suggest unplugging the oven from the wall for a few minutes, then plugging it back in. If it still has a problem, you may need a new keypad, which can be had here: http://www.samsungparts.com/search/search.asp A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Post back here if you need more help. If you don't have the owner's manual, you can download it here: http://downloadcenter.samsung.com/content/UM/200305/20030529152504390_MW1030WC_02601A.pdf
Posted on Sep 28, 2007
6ya staff
SOURCE:
The control panel no longer displays numbers
Hi,if the display is a bluish-green color when it working it is most likely a vacuum flourescent display it is a type of tube that has very fine filament wires in it heated by a low voltage supplied by the control circuit board if this voltage is missing the unit will function but you won't see any display at all sometimes the soldered connections to the tube will fail and depending what ones come loose you can lose parts of the display but if it is all out it could be the filament connections to the display tube these are usually a row of flat thin tabs that connect to the circuit board the filament connections are usually the first two on each end of the row.if they are ok then furthe troubleshooting will be needed to determine if any voltages are missing.M any repair shops just swap the bad control panal for a new one but that could get expensive.I try to service all circuit boards to the component level but sometimes you have enough problems its better to change it IF,big IF a new one is available. Good luck.
Dec 08, 2011 | GE Advantium 120 Convection/Microwave Oven
Our home lost power yesterday, now microwave will not work. Clock is working but it's like the panel is locked. Turned off breaker to try to reset and now on display it indicates 8-:44. Suggestions?
You should be sure that you leave the breaker off for about 15-30 seconds when doing a reset.
If it still won't work right, you either have a defective board or a shorting keypad.
Try the rest several times and note whether the display comes up that same way every time or what.
We can help you with a repair either way.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
Oct 11, 2011 | Whirlpool GH7145XF Microwave Oven
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
Ge spacemaker jvm1653 sho1 display disappears while cooking and shutsdown microwave.Reset display and would function fine for a while. Started to happen once in while now so frequent that oven no longer...
See this FixYa solution. even if your model number is different.
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Display problem on Microwave/Convection Oven
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 07, 2009 | Sharp R-1502 Microwave Oven
Panasonic Microwave Convection Oven Model NN-8501Vstops after one min. of operation-Display goes to all
If you unplug the ac power cord , wait between 30 and 60 seconds and then replug the cord in, push the reset button and then select the time ot cook desired followed by the start button, it seems to work fine for a while (days) and then for some unknown reason it stops after one minute of operation and returns to all eights on the display. A real mystery as to why this is happening and what is really wromg with the unit.
Jul 25, 2008 | Microwave Ovens
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Plate won/t rotate no reheating
PLease open the housing of turn table motor at bottom of the oven and check for the AC input voltages on motor terminals as specified on sticker on motor. for no heating please check fuse between high voltage transformer and high voltage capacitor. Also check high voltage Diode and Magnetron.Please please don't try to measure voltage on terminals of magnetron.
Jul 29, 2007 | Whirlpool MH6141XK Microwave Oven
Samsung MS1040BB Microwave Oven Logo
623 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
