Question about Durabrand DWT1304 13" TV
VCR I have all the Jacks hooked up in the right places- video and audio out on the VCR, and in on the TV. My tapes work, and the VCR plays them, but the TV doesn't play them- nor does it even aknowledge the VCR. I have the channel set on 3 on the VCR and the TV. I can't find my owner's manuel- I wanted to check and see if there's some goofy step I'm forgetting. Please help!
  • JRK9574 Aug 20, 2007
    Thanks! I actually found out what it was- I had to press GAME on the remote- and then it worked! I didn't know that worked like an input button. Thanks though!
    Jess
    Brigadier General:
  • 6,966 Answers
Hi, Based on your post/description, you have to set your TV to AV (Audio/Video) and not on Ch.3. Hopes this work out for you. Good luck and kind regards.
Posted on Aug 20, 2007
  • Louie  Role
    Louie Role Aug 20, 2007
    Hi again,
    If you want to use Ch. 3 of your TV, you need not connect the audio/video output of your VCR to the audio/video input of the TV but rather an RF cord from the RF out of the VCR to the Ant/Cable In of your TV. Your aerial or cable then will have to be connected to the RF in of your VCR.
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Jan 24, 2015 | Samsung Televison & Video
Vcr player won't work. Brand new unit.It's hooked up with Hdmi cord. Dvd will work. But for the vcr it says no signal
To connect the VCR to the TV use the far right VIDEO OUT, AUDIO (R for RIGHT, L for LEFT) jacks to connect to TVs VIDEO IN (yellow) and AUDIO IN jacks.
Feb 16, 2014 | Magnavox ZV427MG9 DVD Recorder/ VCR
What cables do i use to connect to the tv...the vcr has yellow and white areas to connect and the antenna....it tapes, but i do not get a picture when i play it
First off, you need to hook up audio and video by using either an A/V cable or a coaxial to connect the VCR player to the TV, for the A/V cable, the yellow, white and red jacks are coded, match the jacks up with the wires, put one end of the A/V cable to the VCR player OUTPUT jacks and the other end to the INPUT jacks in back of TV. For the coaxial cable, connect the OUT TO TV or OUTPUT jack of the VCR to the ANT. IN or INPUT JACK of the TV. Connect the power cables of both units to wall outlets, and then you're set. Good luck to you!
Nov 19, 2009 | Televison & Video
I insert a tape to play and I can tell from the front panel that it is playing, but does not show up on the screen. Everything seems to be working fine, I just don't know why the tape does not show on the...
Make sure your cables are on the out jacks of the vcr to the in jacks on the tv. Also, you will have to make sure that you have selected the proper external input on your tv to where your vcr is hooked up. Example: If it is hooked up to video one on your tv then you have to select video one on the tv when watching your vcr. I hope this helped.....
Nov 08, 2009 | Samsung Televison & Video
I have a new digital tv. I connected the out
If you are connected by component cables (Yellow/Red/White) from video/audio out, then you will need to select that input selection on your TV, normally AV3. I would also advise using a scart connector from your video to your TV, this would be AV1 on your TV & should then automatically switch over to the Video channel when you press the play button.
Jul 14, 2009 | JVC HR-J692U S-VHS VCR
How to hook up vcr and dvd together ?
|DVD| -> |VCR| -> |TV|
1. Connect your VCR to your TV. (Using Antena cable or RCA cables.)
2. From your DVD player, choose the AUDIO VIDEO OUT. Then, connect that to your VCR's LINE IN jacks.
(*)Your DVD player has 3 jacks coming out. Yellow-video, White- Audio Left and Red- Audio Right.
If you VCR does not have the RED jack. Go to a radio shack and tell on of the sales person taht you need to connect 2 RCA audio outs to 1 RCA audio in. (He/ She will give you a "2RCA Male to 1RCA Female" splitter)
3. Finally, play your DVD, put your VCR channel in TV and most important select the LINE channel in your VCR. (This channal may called as L1, Line,... etc)
You should be seeing the DVD in your TV now.
If you want to play the VCR, just put the casset and play.
Important- The VCR needs to be powered on in order to the DVD signals to go to the TV.
Cheers!!!!
Feb 27, 2009 | TruTech TT1620 DVD Recorder
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Can only get DVD audio when hooking it up to Goldstar VCR...
The DVD must be connected with the RCA jacks-plugs [usually black & red] to the INPUT of the VCR, not to the RF connector. You must press the VCR\TV button to VCR so that the VCR takes control.When you place a DVD movie or AUDIO program it could be copied to the VCR. or played through the VCR.
Nov 11, 2008 | Televison & Video
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Hooking updta800 converter
Hopefully, your HDTV has a 'Video out' RCA jack on the back-some don't. You could try connecting from these video/audio out jacks to the RCA video/audio in jacks on your VCR. If it works, remember it will be recording EVERYTHING on the tv screen(Time, channel,etc.) that you see while watching. So if you change the channels on the tv-it will be on the tape.
May 25, 2008 | Televison & Video
Durabrand DWT1304 13" TV Logo
76 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
