Car Video Players
Problem for Car Video Players
Generic problem for all Car Video Players
DVD in the player starts from beginning eac...
By tnasser on Mar 23, 2009
Is there a way to have the DVD in the player pick up at the same place in the movie that it was at when the car's ignition was turned off? Each time the car is turned off or the player is turned off and then back on again, the DVD starts from the very beginning. Is there any way to have it remember the place in the movie and return to it when the player is turned back on?
Comments:
Mar 23, 2009
- The DVD in the player starts from the begining when the player is turned off and back on again even if the car remains running and there is power to the player.
Mar 23, 2009
- Good suggestion. It is a Tru Tech Model LMD-5702RT 7" Player with a single 7" monitor. I have checked the manual and it was no help. There is a setting in Setup that says "Last Memory" and "On" = The Unit will return to the last position on the disc. I set it to on and it does return to the last position on the disc if I hit the "Stop" button and then "Play", but not if I turn it off or turn the car off and cut power to the player.
Solution #1
posted on Mar 23, 2009
Somewhat Helpful)
odiebugs
Rank: Guru
Rating: 88%, 240 votes
Well yes, kind of, you would have to have a dealer wire this hot so that it did not lose power to it when the auto is turned off. This is not a great idea as if someone left it on it could drain the battery after a while. You would have to have a dealer do this because any electric
work that is not done by the dealer can and will void your warranty,
yes a car starter,raido,if it is not done by your factory dealer, they can deny your warranty. The other option is to have a different player installed that had non volatile memory, which would hold settings when the power was removed.
I would read the manual of this devise, it could have an option that allowed this before you do anything drastic. If it was me, I would just make the kids fast forward it. Sorry if I could not be of more help. Hope it works out for you.
Comments:
Mar 23, 2009
- If you could post what make and model it is, we could see if there is a way to not let it do this. Most players will start where they where left off. But it depends on the model, maybe it is listed somewhere
on the player itself or in the manual of the auto.
Mar 23, 2009
- I have checked, and you are right, this is the only thing is see for
holding its memory. The manual is no great help, and I bet that when you remove the power last memory resets to off, they did not want to make it easy for you.
I am not trying to make you more unhappy than you already are,but
for future reference, while checking around I seen a lot of people
having problems with there players and some are very unhappy.
I don't see anything else to overcome this, again sorry I could not be of more help.
Was this helpful?
Yes
No
Popular Solutions for Car Video Players
Questions and Unsolved Problems for Car Video Players
Answer
boss bv9560 - can I hook up my subwoofer to this?
Answer
I have a 2wd, no sunroof SR5 sequoia and would like to install a dvd/video player on it. Are there... (More)
Answer
xo vision xod1741bv it keeps jumping from mode to mode and will not stop on any one place
Answer
turn off all light boss work fine but if u turn on light boss reciever not working and car- show on... (More)
Describe your Car Video Players problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Video Player Experts
Top Audio & Video Equipment Repairmen
in Newport, KY
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
