Question about Olympus EVOLT E-500 Digital Camera
EVOLT E-500 LCD Problem (Mirror Image)
The screen on my Olympus EVOLT E-500 screen is now reversed. Everything including the menu, pictures, etc. is the mirror image of what it should be. Anyone heard of this problem?
  • harley-man2 Dec 06, 2008
    everything in my viewfinder is mirror image including menu pictures everything
    Genius:
  • 2,985 Answers
This is new one one. It would seem to be an electronic failure of some sort Suggest you refer to Olympus Support on this one
Posted on Aug 20, 2007
I own an Olympus Evolt E-500. Unfortunately, it was dropped and landed on the corner of the case near the battery door. The camera turns on, lcd screen, flash, and shutter seem to work, BUT pictures are...
I found this camera available for purchase as brand new for $450. Spending nearly $300 to repair an older version may no be a wise choice. You may find there is a market for the camera in its current non-working condition on eBay.
With that said, to your questions. 1) It will be difficult to diagnose without seeing it, but I have a suspicion in mind.
The viewfinder picture is actually what the lens sees, bounced up via mirror to a prism that projects the image to the viewfinder. If the mirror has become dislodged and is stuck in an odd position, the image would not be projected in the viewfinder. You can see the mirror when you remove the lens from the body. The mirror should be centered in the opening but at about a 45 degree angle. If it is loose or otherwise in the wrong place, this could be the problem. If the mirror is stuck and preventing the image in the lens from projecting on the sensor (behind the mirror) no capture will be possible. Other than the optics inside the lens and the mirror, there are few parts that could obstruct the image in the lens from reaching the viewfinder. Is the aperture of the lens open? If not, there may not be enough light to see the image in the viewfinder. This would also indicate that the lens is not opening up to let you see, and may not get set to the correct aperture when taking a picture. The camera usually opens the aperture to allow you to have a nice, bright image in the viewfinder. When you press the shutter release, the lens stops down to what the program says (or your manual selection) and the mirror lifts up out of the way, and the shutter fires.
2) Can you fix it? Maybe. Again, without seeing it - its hard to know for sure what the problem is and I don't know your level of skill either.
My suggestion is to bypass the camera shop that "doesn't know what the problem is but will fix it for $270" (how is that even possible??) and deal directly with Olympus USA Service and Support by phone or email to get an estimate / factory trained tech perform the repair.
Mar 08, 2012 | Olympus EVOLT E-500 Digital Camera
The view finder darkens every time i take pictures
That's how a DSLR camera works. When you are setting up the shot, the image through the lens is reflected by a mirror up to the viewfinder. When you snap the picture, the mirror flips out of the way so the image can be registered on the sensor and then the mirror flips back. So, for that time, there is no image in the viewfinder.
Jan 07, 2011 | Olympus EVOLT E-500 Digital Camera
My olympus e-500 will not display an image before taking a picture. Display is working for menu, review, etc.
In order for your camera to display the scene on the screen before you take the picture (the way point-and-shoot cameras work) it would have to have a feature called "live view". Your camera, as far as I know, doesn't have it.
Aug 30, 2010 | Olympus EVOLT E-500 Digital Camera
I have an e500. The viewer will not come on for taking pics.
Unfortunately with the EVOLT E-500 it does not have the capability for a live view LCD screen. You must shoot images using the viewfinder only. The newer Olympus SLR cameras now have both viewfinder and live view LCD.
Jul 17, 2009 | Olympus EVOLT E-500 Digital Camera
LCD montior not on to see picture before taking picture
On the EVOLT E-300 it is not a camera that has a live view LCD screen that will allow you to see the image before it is taken. You must take the image with viewfinder only and only use the LCD screen for review purposes. This is how the camera was designed.
Mar 15, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
Display not on
The EVOLT E-500 does not have a live view LCD screen so you can see the image you wish to take a picture of. You must use the viewfinder to take images with this camera and only use the LCD to review the images.
As far as to reset the camera back to factory defaults, you need to turn the camera dial to P go to the Menu and on the camera 1 tab right arrow over and then arrow down to custom reset setting and then hit the right arrow highlight reset and press ok it will show reset yes or no highlight yes and press ok this will reset the camera back to its factory settings
Mar 02, 2009 | Olympus Camedia C-5050 Zoom Digital Camera
Olympus E-500 view in LCD whwn taking picture
It is not available while taking pictures on the E500. After you shoot a picture you can program how long you want the picture to show then disapear. Thats the only option for the LCD.
Nov 22, 2008 | Olympus EVOLT E-500 Digital Camera
Image Reversed on LCD
THE LCD HINGE MAY NEED REPLACING.
May 02, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Wont take Picture
Check for the obvious -- shutter speed, aperture, and ISO set appropriately to give you a well-exposed image, and lens caps off. If none of those are the problem, then there's a problem with the mirror, the shutter, or the sensor itself. You can carefully look inside the mirror box with the lens removed, and see if anything is blocking the motion of the mirror. If you don't see anything (or, honestly, if you do), take it to a trusted camera shop or call Olympus's repair center.
Jan 02, 2008 | Olympus EVOLT E-500 Digital Camera
No picture on my LCD
When in the taking mode- this SLR will not show an image as other cameras- because the mirror is down for the reflex view finder- this is normal for this type of camera although I understand there is a make/model that gets around this - but it is not the E-v 500 just like my E-v 300
Jul 02, 2007 | Olympus EVOLT E-500 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
205 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
