Question about Samsung Yepp YP-T7JZ MP3 Player
Time and date.
I want to change my time and date. But, it only will let me change the hour. I pushed every button, nothing seems to work. what do I have to do?
  • Alexis Meier Aug 20, 2007
    this still didnt work!
    President:
  • 1,114 Answers
You can download the manual from the link below: http://downloadcenter.samsung.com/content/UM/200509/20050922101326796_YPT7J-SEA-ENG1.0.pdf It seems the players date & time are set when the player is connected to your PC to transfer music. Make sure the date & time are set correctly on your PC then connect the player & it should update. You can only change the hour in case you travel & change timezones. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 20, 2007
  • Greg Cann
    Greg Cann Aug 21, 2007
    OK, 3 things to try,
    1. Use Windows Media Player 10 or 11 and use the "sync" option from the tab in the top toolbar.
    2. Reset the player to factory settings.
    2. Upload new firmware from the following link:
    http://www.samsung.com/us/support/downlo...
    If one of these does not fix it I'm stumped!
SOURCE:
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
I have a small alarm clock with model # alck-487 and three buttons M, S, D. i can't find the right combo of push and/ or hold to change the time. can you assist?
ALCK-487 reset time:
Press M three times, you will see the seconds flashing.
Then press S once to adjust minutes, press D,
press S a second time to adjust hours, press D,
press S a third time to adjust date of month, press D,
press S a fourth time to adjust month, press D,
press S a fifth time to adjust day of week, press D,
Then press M to end settings.
Mar 11, 2014 | Audio Players & Recorders
How do I set the time on a philippe starck ph1110? There aren't any buttons to push...
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker
Dec 30, 2011 | Watches
I plugged in my Emerson Smartset Clock Radio (model CKS2005) and the date is off by a couple. Today is August 4, Thursday, and it states August 7, Saturday. How do I change the date? The date button is...
You have to run the clock back. Press Time/Date and then press up or down after you run it 24 hours the date will change, and the date will move day to day.
Aug 05, 2010 | Emerson Smartset Clock Radio
Change day but not date on Timex Expedition
HI..
HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
  • Step 1 Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
  • Step 2 Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
  • Step 3 Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
  • THANK YOU
  • Jul 28, 2009 | Timex Expedition Outdoor Athletics Watch...
    I can change everything but the date. How can I change just the date on my watch. The model I have has 4 buttons (Mode, St/Stop, Set, and Light). Can someone tell me how to change nothing but the date?...
    Hi 1234910,
    To set the digital time and date on your Timex, please follow the steps below.
    1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
    2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
    3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
    4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
    5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
    6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
    Hope it helps.
    Thank you for using FixYa.
    Jul 16, 2009 | Timex 1440 Nylon watch
    Changing the time on my wristwatch
    For the Amritron 45/6975:
    From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
    Mar 08, 2009 | Armitron Two Tone Sports Watch
    Armitron Watches
    From the time telling mode press the set button the seconds will flash.
    Press the mode button the hours will flash
    Press the adjust button to change the hours
    Press the mode button the minutes will flash
    Press the adjust button to change the minutes
    Press the mode button the month will flash
    Press the adjust button to change the month
    Press the mode button the date flashes
    Press the adjust button to change the date
    Press the mode button the day flashes
    Press the adjust button to change the day
    Press the set button when done.
    Mar 11, 2008 | Watches
    How do I change time on timex watch?
    These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
    These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
    TIME AND DATE
    1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
    2. Press ADJUST to set SECONDS to zero.
    3. Press START/STOP to select MINUTES.
    4. Press ADJUST to change.
    5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
    6. Press MODE when done.
    7. To display DATE from Time display , press START/STOP.
    8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
    9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
    ALARM AND HOURLY CHIME
    1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
    2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
    4. Press ADJUST to change.. Press MODE when done.
    5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
    CHRONOGRAPH
    1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
    2. With time displayed, press MODE to select Chrono Mode.
    3. Press START/STOP to start.
    4. Press ADJUST to view lap time. Press again to sesume lap timing.
    5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
    6. Repeat for successive laps.
    Have fun! - Not a bad watch for the money! - - Silver Bullet
    Mar 16, 2007 | Timex 5B841 Wristwatch
    Samsung Yepp YP-T7JZ MP3 Player Logo
    95 people viewed this question
    Top Samsung Audio Players & Recorders Experts
    Mike Duncan
    Mike Duncan
    Marvin
    Marvin
    Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
