Question about Kenmore 64802 Top Freezer Refrigerator
Our refrigerator stopped working, compressor not kicking on.
The compressor is attempting to come on but fails.It starts off by making a long hum and shuts off with a click. The fan and light are working. We have cleaned the coils as suggested in the manual, but it did not do anything to help it. Is it possible that the thermostat is going out? Our refrig is only 2 years old. We bought it brand new when we bought our house. What can we do to fix this problem?
  • SriniVoleti Aug 25, 2007
    Replacing the Relay start solved the problem. Thank you for the help.
Sounds like the problem that I had. The repairman replaced the relay switch, which is usually located behind the refrigerator, bottom left.
Posted on Aug 20, 2007
SOURCE:
APE08AJM1 - GE 115 Volt Portable Electronic Room Air Conditioner - Compressor not kicking on. Manual indicates it's triggering the overload relay? How do I solve this?
There is a start capacitor near the compressor that may be bad. If the capacitor tests OK then the compressor is locked up. A service man can try to get it going with a kicker capacitor but there is no guarantee that that will work.
Sep 14, 2017 | GE Heating & Cooling
Moved my GE side by side that's about 13 years old to the garage. I left unplugged for the last 4 months. I plugged it in and the light works but the compressor is not kicking in. worked fine befor
https://www.repairclinic.com is a good place to get troubleshooting ideas. Does the compressor make any sounds? There is usually some sort of starting relay or circuit to start the compressor and then switch to run mode. It is often inside a small box mounted on the compressor. If relay fails compressor will get very warm and make clicking or humming sound.
Jun 26, 2017 | GE Refrigerators
Fridge started to make a humming Unplugged it,let it sit for an hour,it was fine.water on the floor from the ice-and I unplugged it for the night.I got up shook it-worked for 2 weeks.
What sort of "humming" noise? Refrigeration systems rely upon vapor compression to operate -- meaning occasionally to maintain temp a compressor will kick in which can hum.
Sep 01, 2015 | Frigidaire Refrigerators
My GDM-12 is not cooling. when I turn the temp up it make a loud humming sound.
If the humming last 3-5 seconds then makes a faint click sound and stops humming for a minute or two. Then resumes the hum again it may be your compressor locked down. Stuck. Most likely it is just a bad start capacitor not kick starting the compressor. A $6 part.
Mar 07, 2014 | True GDM-12 Refrigerator Commercial
Amana refrigerators is not staying cold and freezer is not freezing. Makes a "humming" sound, on and off, like a low "grind" noise, or like the noise an airconditioner makes prior to kicking on.
Mine had the same problem, and I had a tech out today who determined it's the motor inside the freezer. It's (the fan) not running. It's a $100 part, but if your refrigerator is new enough, it's probably worth the investment to go ahead and have it fixed.
Jul 29, 2009 | Amana ABB1927DE Bottom Freezer...
Admiral Refrigerator/Side by Side
compressor or sealed system issue compressor is failing or a problem in the sealed syetem is putting a back pressure onto the comperssor causing the compressor to eventualy kick of on the internal overload in the compressor, cools down as you unplug the unit allowing the compressor to cool down resets the internal overload runs and repeats the process
have the unit checed by a quilified tech in ref sealed system repair
May 27, 2008 | Admiral 26 cu. ft. Side-By-Side...
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Dec 06, 2007 | Maytag MFI2568AE Side by Side French Door...
Whirl pool side by side refrigerator problem
It looks like the Capacitor Start Relay is failing.  It is located either on the starter Relay or mounted on the side of the compressor compartment.  It sould have two wires on it, one orange and the other probably white.
Oct 22, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerator not cooling.
compressor has failed. not a diy job
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
259 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
