Question about Canon PowerShot A520 Digital Camera
Camera will not retain time setting
Upon power up, my Canon A520 asks for date and time to be set. when I set it, this only lasts until the camera is shut off. this is regardless of the state of the camera batteries...i.e. same thing installing brand new batteries.
Firts check the state of the litium battery, this is locate near the Audio/video port in your camera, with small flat screw driver you will be able to remove it. If the same situation occur after replacing the litium battery and i'm assuming the unit had never be open before unfortunately your camera needs new main board ass'y. But if the case is that some one open the unit before check for a loose conector from the litium unit to the main board.
Posted on Aug 31, 2007
The time and date setting of my canon powershot a520 always pops up in the window of the camera eventhough i set it. It usually shows when I on the camera,shot a picture and playback the picture.
CoolJoe72 only posted one answer, but it was a good one, and it applies directly to you. Check it out here: http://www.fixya.com/support/t313710-having_reset_date_time .
(The short answer is that you need to change the date battery, which you'll find under the terminal cover; it's a CR1220.)
Mar 23, 2011 | Canon PowerShot A520 Digital Camera
Hello, When I just bought this camera several years ago, I entered the time and date settings and after I've done this it never asked for time/date settings again. But now every time I turn on the...
you may need to take it in to the camera place to get the internal batery for the clock replaced also you may need to up load the driver program for the camera
Aug 15, 2010 | Canon PowerShot A520 Digital Camera
Polaroid a520 will not keep the date
You may want to set the factory defaults by going into the main maenu.
Nov 22, 2009 | Polaroid a520M Digital Camera
Everytime I turn the camera on the time and date
There are two batteries in the camera. One is the big one you charge and the other is a little coin type battery. This coin battery maintains your settings and when it goes your camera forgets things. Same setup on computers and a lot of other electronics. In your camera the battery is a CR1220 worth about $1-$2. It should last about 3-5 years but you never know.
The battery is in a little holder on the left hand side of the camera. Its under the same cover as the usb connector and power plug in. You should be able to pop out the battery holder fairly easily. This is one of those things that if you take the camera to a battery store they will probably do it for you if they aren't busy. If you look at page 137 of your manual you will find the instructions for doing it yourself.
Sep 12, 2009 | Canon PowerShot A520 Digital Camera
I am trying to set date time in my camera(canon sx110is). But in every power on it is reseted. Whatever date i am setting in this camera is not stored in the memory. In every power on it asking for...
You have to change the 'date battery'. Use the user manual to find its location.
Mine is Canon A520, located beside the cable link sockets. Battery is CR 1220.
Dec 16, 2008 | Cameras
I bet you can't solve this.
We have a Canon A520 and it was having all the symptoms noted. Searched for a resolution on numerous sites including the Canon Support site. While on the Canon Support site, I found an FAQ on "How to RESET the A520". Turn camera on, find and hold MENU button for 5+ seconds until "Reset settings to default?" screen appears. Arrow over to OK and press the SET button. When we did this the battery low indicator showed, replaced batteries with standard alkaline batteries. Everything functions properly, with no additional problems for the past 5 days. I guess the camera just lost its mind and had to be defaulted and rebooted, hope this helps.
Oct 01, 2008 | Canon PowerShot A520 Digital Camera
Having to reset date and time
Solution: Replacing the date battery PowerShot A510 and A520
Replacing the Date Battery If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution_a70.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids could damage the stomach or intestinal wall.
  1. Confirm that the camera is turned off.
  2. Open the terminal cover and use your finger nail to pull out the battery holder.
  3. Pull open the battery holder in the direction indicated by the arrow (1). Remove the battery by pulling it up in the direction indicated by the arrow (2).
  4. Insert a new battery with the ( ) side facing up.
  5. Replace the battery holder back and close the terminal cover.
  6. When the Date/Time menu appears, set the date and time.
note_icon_a70.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your country.
Dec 24, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot A520 Digital Camera Logo
394 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
