Question about Sony PlayStation 2 (PS2) Console
Ps2 my ps2 light (green and blue) wont turn on when i turn my ps2 on and when i open it i found out a sliver strip next to the tray has been removed from a chip i know which chip it was but how do i put it back on and where
  • n killer60 Aug 21, 2007
    ya but where do i put it back in like under it or where
    yhea but where do i put it in at?
U need to get some pliers and put it back in...i had this same problem before
Posted on Aug 20, 2007
SOURCE:
My playstation2 wont turn on the red button is on. anyone have some feedback on this issure
You need to press the red button to get the system to turn on. It should show a green light. There will be a blue light next to the green light if you also have a game inside.
Feb 10, 2010 | Sony PlayStation 2 (PS2) Console
PS2 is on, but no signal
The tray has become misalligned. If you want to fix it on your own heres what you do. Remove the 6 (or 8 depending on generation) screws on the bottom. Remove the warranty sticker on the back by the power switch. With the front towards you, lift the top while tilting slightly toward the front and pivoting it by the power/eject buttons. Either remove the button assembly by popping it off the lid or just be careful not to tear the cable. Remove 4 philips screws from the cd mech lid and lift off. Remove two philips screws from the tray hinge. Lift and slide tray out of front. Push white gear frame at front of tray area to the right and hold it there while you put the tray back in. Reassembly is reverse of disassembly.
Sep 13, 2007 | Sony PlayStation 2 (PS2) Console
Green light turns on but blue light dosent turn on. Also the ejection tray dosent come out.
ahh my friend had the same problem
if you had opened your ps2 the cord connecting to your motherboard for the tray the cord probably came off its a gray cord you take your ps2 apart and it connects the top part to the bottom part just reconnect it to the insertion point it connected to and you should be back in businesas
Nov 30, 2009 | Sony PlayStation 2 (PS2) Console
My Ps2 wont turn on
take the ps2 apart and take the disc tray out the strip connects under it
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
Black screen, no disc spin or eject, fan spins
That same thing happened to me. I disassembled the ps2 to find out the problem, I found out. If your console does not turn on or no lights check the silver ribbin connected to the reset button. See If it is in all the way the top and the bottom of the ribbin or check to see if there are any tares in it if there is replace it . You can get good parts off of Ebay.
Nov 08, 2008 | Sony PlayStation 2 (PS2) Console
Wont go on.....
My PS2 Slim sliver will not even show a red light, I took my ps2 apart to clean a sliver peace fell out it has a hole in it. I need help to fix it.
Oct 17, 2008 | Sony PlayStation 2 Slimline Console
Getting ps2 micro switches realigned
micro switches is wat turns on and off the PlayStation2 and they make the Cd tray come out and resets the ps2 the buttons are the green button on the front of the ps2 to restart and turn on the ps2
and the blue button is at the bottom of the green one the blue button makes the Cd tray come out and the last micro button it at back of the ps2 its a black button that turns off and on the ps2
your rating is highly appreciated
Jun 23, 2008 | Sony PlayStation 2 Slimline Console
Yellow light
  1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
  2. There is a paper jam in the printer.
  3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
  4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
    1. Pull the tray out of the printer and remove any paper.
    2. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
    3. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
    4. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
    5. Slide the tray back in the printer.
  5. The tray 2 paper level indicator is stuck. (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974).
  6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
    1. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
    2. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
  7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
    1. Turn the printer off.
    2. Press and hold down the green GO button.
    3. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
    4. Release the GO button.
      NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
    5. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
  8. If the issue persists, please contact Hewlett-Packard's Customer Care phone center for further assistance. at http://www.hp.com/support.
Mar 12, 2008 | HP LaserJet 1320n Printer
My ps2 light (green and blue) wont turn on when i turn my ps2 on and when i open it i found out a sliver strip nest to the tray has been removed from a chip i know which chip it was but how do i put it...
The ribbon cable should have a stiff plastic reniforcement atached the the end. you get a Pair of Precision needle nose pliers and insert the ribbon cable in the holder, I think you are calling this a chip. There are no holds or clips , just grip to hold the cable into the socket. WWW.playstionclinic.com can help if this does not work.
Aug 20, 2007 | Sony PlayStation 2 (PS2) Console
PlayStation wont power on
The jumper between the buttons and motherboard may be disconected. Open up your ps2, see if there is a blue /white ribbon cable that is unpluged. If you have already opened your ps2 rrior to this, thr case map be jamming the button.
May 06, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
231 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
