Question about Tomtom GO 910 GPS Receiver
Tomtom 910 will not power up
When I plugged the gps into the cigarette plug, it worked fine and I was able to use it after a few days like a pro. This morning, I turned it on, and after a few minutes it just turned off. The green light in the left corner stays lit but it will not come on at all. The screen stays black. Any ideas would be appreciated.
In a back of your GPS there is a small whole. You have to press with toothsstick to reset it.
Posted on Aug 24, 2007
SOURCE:
My cigarette lighter will not charge my TomTom
The plugs which are used with car lighters are often very poor; compare the firmness of the seating of the lighter with your accessory plug. The latter are often too loose to make decent contact.
Also, that plug is equipped with a fuse; unscrew the plug body and check the fuse.
I also recall someone having a failed plug on the Tomtom itself; it may be a weak point.
Jul 08, 2010 | Tomtom ONE GPS Receiver
TomTom GO 910 won't turn on.
Two possibilities:
- if someone has used the wrong charger, and connected it to a 12V supply, the mainboard may be damaged. In that case, you need a replacement.
- the battery may be discharged. Even if the green light is on, it doesn't necessarily charge up. Try pushing it hard onto the mount for a few minutes, then see if it will turn on.
Feb 08, 2010 | Tomtom GO 910
The grean light comes on, but it won" power up, Also does it have a reset? It's a tomtom 910
There's a reset on the bottom, next to where you plug it in. A small paper clip will fit. Push it in LIGHTLE to reset the unit.
Oct 22, 2009 | Tomtom GO 910 GPS Receiver
My tomtom 910
Have same thing. I did call Tomtom and they are guessing ,just like me ,that battery is dead and offered me US$ 75 off brand new go 730 and old one u can keep. Was told ,they dont sell battery replacement .
Sounds like someone will sue their **** soon as class action .
Sep 05, 2009 | Tomtom GO 910 GPS Receiver
Tomtom 910 not switching on
A hard reset is done by pushing a paperclip into the reset hole on the bottom.
May 19, 2009 | Tomtom GO 910 GPS Receiver
The tomtom was working fine. Then I think I left
The 910 has a small reset button in the area of the socket. You will see a small circular notch molded into the housing near the socket. A small paperclip will fit in the reset hole. Reset the unit and it should start normally.
May 07, 2009 | Tomtom GO 910 GPS Receiver
TomTom will not switch on even when it is plugged into the mains power
yes just press the reset button under the tomtom you can find this next to all the pins where your tomtom dock goes in.
Dec 17, 2007 | Tomtom GO 910 GPS Receiver
PC not recognizing Tomtom
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
Nov 12, 2007 | Tomtom GO 910 GPS Receiver
Red x on my tomtom go one
Tomtom GO 910 GPS Receiver flashing white X in a red circle
I discovered that there was a file on the 910 called CLMDATA which was corrupt. When I deleted this in Windows explorer, the unit started up and worked OK. This file is recreated when the unit starts up
Oct 28, 2007 | Tomtom GO 910 GPS Receiver
Not turning on
You will need a paperclip/staple. http://www.tomtom.com/support/index.php?FID=6965&Lid=1
Aug 23, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
221 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
