Question about IBM WorkPad c3
Dark screen when unit is turned on screen breifly flashes correctly, then goes black. resets didnt help. did not do hard reset.
    Problem Solver:
  • 4 Answers
Turns out the little button on the top left of the device is for adjusting the contrast. Turn on the WorkPad. Press the little button. Then hold down the down button and the contrast will be adjusted.
Posted on Jun 01, 2009
SOURCE:
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
MY SONY EREADER ISNT WORKING AT ALL. THE RESET BUTTON WILL NOT DO IS JOB AND THE ONLY THING ON THE SCREEN IS ROTATING ARROWS.wHEN I CHARGED IT DIDNT TURN YELLOW.iTS BEEN LIKE THI9S SINCE CHRISMAS AND IT IS...
Hi huffasia,
Looks like a charging problem, try this:
1. Connect the reader to the computer and make sure red steady light comes on, if not, then hit the reset button for 3 seconds.
2. Once you get the redlight, leave the reader charging for 15-30 minutes (make sure the computer does not go into sleep mode)
3. After you charge the reader, try the soft reset again and slide the power switch at the top of the unit.
If this does not resolve the problem you may try a hard reset on the reader but this will remove all content.
To hard reset:
1. Hit the reset on the bottom of the reader
2. Slide the power switch
3. Once "Opening Book" comes on the screen, press and hold the directional "down arrow" and the number "0" both at the same time until "Reset All" appears on the screen.
4. The screen will go blank, now its time to turn it on again.
Note: If after trying the hard reset, the reader goes back to the black arrows trying to turn around, then repeat the steps again.
Hope this helps!
eBookBoy
digialreader.freeforums.org/
May 16, 2011 | Sony E-reader Portable E-book MP3 Player
My New Garmin Nuvi 1400 will not turn on - it just gets to the screen "Loading maps" and then the screen goes black. I have tried the suggested holding down the power button for 10 seconds, but nothing...
My Garmin Nuvi 1490 was on for five or six hours driving then the screen went dark and now unit will not turn on or light up screen at all ? ANY HELP OUT THERE ?
Feb 09, 2010 | Garmin nuvi 1490T GPS Receiver
TI-83 screen is black
The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
Aug 29, 2009 | Texas Instruments TI-83 Plus Calculator
My 3100 comes up with the warning screen ,flashes and then the screen goes dark.I tried the reset switch to no avail.Please help,I am "lost"withouth this device.thanks,Randy
first, make sure it is fully charger..let it on a charger at least a few hours, then try the hard reset again (little pin hole on the side near the bottom.
Jun 23, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Screen goes black after like 10seconds
first try resetting the phone if it didnt work you have to flash the the phone witha frest software
May 07, 2008 | Sony Ericsson K800i Cellular Phone
Dark screen
Hello there:
It seems like ur hdd is not working propertly
or Ram
or VGA check those 3 and if they are ok WRITE HERE back.OK?
Nov 07, 2007 | Gateway 450ROG Notebook
IBM WorkPad c3 Logo
184 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
