Question about Brother MFC-5440CN All-In-One InkJet Printer
Disk full error
When I try to download faxes to the computer (WIN XP Professional) I occassionally get a disk full error. I am using the Brother MFL-Pro Suite. This stops all other faxes from downloading and I have to clear the printer's memory before I can download more files. I have been reduced to printing all faxes because I can't rely on the program to send them to the computer.
    New Friend:
  • 74 Answers
I don't think you can even do this
Posted on Apr 15, 2008
SOURCE:
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8 Home Edition http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8030 Professional Edition set up disks for floppy http://www.download3000.com/download_17676.html XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
Remove windows from acer aspire 5100
I think you have dual Os on it i.e Win XP & Win Vista. So, I am sorry to say that you can not access the full factory restore from the recovery partion. At this point, I would suggest you to contact the Acer Technical Supprt and order for RCD (Recovery Disk) inorder to wipe everything from the computer or you can use a Disk Manager utility to wipe everything from the computer.You can visit the below link to download the software
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
http://www.brothersoft.com/downloads/format-hard-disk.html
May 24, 2010 | Acer Aspire 5100 Notebook
I have 2 HDD's in my PC - both with Win XP Prop
Boot.ini is correct, but looks default is booting from Disk2 and partition 1 which is your G:\ 500 GB.
Try Copying boot.ini from c:\boot.ini to g:\boot.ini It might help
In your example I see missing "\" after partition(1), may be typing mistake, but in real time can generate error.
You boot.ini looks exactly same in both drive c:\ & G:\
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="GUY DRIVE XP Professional" /noexecute=optin /fastdetect
Note: boot.ini will be hidden and readonly file. You need to unhide the file and remote the read only option and then only you will be able to save the boot.ini file
Hope this helps
May 22, 2010 | Microsoft Windows XP Professional SP2
I have windows xp professional and when I run my
If you get the error-message when you try to boot your computer, your disk-drive is either:
1. not connected to the motherboard
2. improperly connected to the motherboard
3. dead/dying, so that the Operating System files on the disk-drive *CANNOT* be read.
So, the computer tries to boot from an "alternative" device (either the 3.5-inch device or the CD-ROM device) -- if you don't have any media inserted into either device, you will get the error-message.
Oct 25, 2009 | Microsoft Windows XP Professional SP2 Full...
NTLDR missing on changing harddisk connection
put the xp bootable disk in computer and boot from it, choose repair option. it will slove your problem.
Feb 24, 2009 | Microsoft Windows XP Professional With...
Need a full win xp installer with sata driver
which is the version of xp u have.. i think xp sp2 has the xp drivers or you can manually load the drivers when trying to install xp pressing a f6 key.. for which you must have the floppy disk with the sata drivers from the hard disk manufacturer..
Nov 06, 2008 | Microsoft Windows XP Professional With...
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Nov 29, 2007 | Microsoft Windows XP Professional for PC
Win xp pro setup
if you have the original xp disk with a cd key , then its perfectly legal for you to download a iso copy of xp , and install it, if not try and make a copy of the disk , and use that , or someone u know may have a friend with a xp disk , thats fine also aslong s you use the key that comes with your disk
Nov 26, 2007 | Microsoft Windows XP Professional for PC
Unable to open icon T-Sonic 610 MP3 player icon in Win - XP
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Oct 26, 2007 | Transcend T.sonic 610 MP3 Player
Brother MFC-5440CN All-In-One InkJet Printer Logo
123 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
