Question about iLO MP3 Player
MP-556 MP3/WMA PLAYER
I am having problems downloading music to my MP3. The Windows Media is not detecting the device to synchronize music for download.
  • 3 more comments
  • Anonymous Nov 04, 2007
    windows media not reconizing mp3 player
  • tonik12 Nov 27, 2007
    I don't know how to put music on my MP3 PLAYER
  • fat basterd Dec 04, 2007
    I have not been able to download anything to this at all.
  • Anonymous Mar 27, 2008
    i have failed to downlod music to my player even by drag and drop.it's mp-556
  • Anonymous May 12, 2008
    My computer is not detecting the device on Windows Media Player
    Problem Solver:
  • 15 Answers
Http://www.lenoxx.com/2005/mp3player/mp556.htm if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working.
Posted on Aug 27, 2007
    Problem Solver:
  • 11 Answers
Okay, first make sure you have the right version of Windows Media Player. If you aren't sure, it should be on the CD that you should have gotten with the mp3 player. It will automatically download the software you need if you don't have it. If that doesn't work, then try going into add/remove hardware in the control panel. It will search for hardware that is plugged in. When you have it plugged in, try and search for it. It should find it and then you should be able to use it.
Posted on Aug 21, 2007
LOADY
Posted on Jun 01, 2008
SOURCE:
How do you download music to an mp3 player from a cd?
Normal audio CD tracks should be converted to mp3 files onto the computer's hard drive, first.
This is called ripping or RIP function.
There are several programs that can RIP audio CD.
It is important to convert music into the correct bitrate for the player to match for playback. (192 kbps is good quality and often used)
You can use Windows Media Player 10 or 11 for conversion.
When you use WMP 10 or 11 and the player is detected in the program:
1. Tell the player were your music library is: setup your music library.
2. Create a playlist; make playlist name and add mp3 files to the list.
3. Synchronize the playlist with mp3 files to the player.
If the player cannot be detected in WMP 10 or 11, but only can be viewed as a removable disk in "My Computer" : use the "copy and paste" or "drag and drop" method to put mp3 files from the computer onto the player.
When needing more help, don't hesitate to write a comment in this reply.
May 01, 2010 | Coby MP-C653 MP3 Player
Download from audible
hi,
Have you tried connecting to the net and then continue to subscribe??
Feb 09, 2008 | SanDisk Sansa Clip MP3 Player
Cannot download
Make sure you are trying to sync .MP3 or .WMA files.
If this is the case check out the error code number on the Microsoft website.
Feb 24, 2008 | Philips GoGear Flash MP3 Player
Help with copying music to my mp3
I have the same player. Are you just dragging and dropping songs on to the player? I use Windows Media Player 10 to put music on the player. It has a function called SYNC. What that does is take your music from WMA 10 (WMA, MP3 files, etc...) and transfers them to your mp3 player. You might give that a shot. Also, WMA 10 should recognize your player and let you connect with it.
Feb 16, 2008 | Coby MP-C582 MP3 Player
Ilo mp-556
what you might want to do is to rip the songs from the cd as an mp3 songs/go to your windows media player tools setting and change the rip file to MP3 instead of WMA...
Jan 16, 2008 | iLO (2 GB) MP3 Player
Will my mp3 player work with vista
This player only seems to be able to transfer MP3 format with Vista, using windows media player syne. Unless someone found otherwise.
When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer folder hierecy. The MP3 player is not able to reconginize the folder structure it usually creates.
Dec 26, 2007 | iLO MP3 Player
Ilo mp3 player 1g
Got a new SD Card + Card Reader but when I download my music on it...
You cannot just move WMA songs onto the card and play in the MP3 player. MP3 format may work this way, but for sure the player only seems to be able to recongize WMA files when syncd through Windows Media with the USB cord attached. Be sure the DESELECT 'copy folder hierecy' under the sync options/properties of the MP3 player drive or SD card drive.
This player only seems to be able to transfer MP3 format with Vista, using windows media player sync. I can syne MP3s formats, but not WMAs at all. Unless someone found otherwise
Dec 25, 2007 | iLO (2 GB) MP3 Player
Ilo mp-556 mp3/wma player
i have a problem when ever i wanted to switch from card to flash it shut self off,i had to take the card out to play other .i have 1G any idea?
Nov 25, 2007 | iLO MP3 Player
2,194 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
