Question about Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe cleaning grinder
How can i disarm the grinder of a saeco magic de luxe sup 012? i lost the manual and i do not know how to clean it, the coffee doesnt taste good anymore
  • Anonymous Mar 24, 2014
    The coffee doesnt taste as good as it once did
  • 29 Answers
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Posted on Aug 27, 2007
I took apart my saeco magic de luxe grinder .....I forgot to mark the settings....on the inside there are a blue & red mark...when aligned with the blue lines I can remove the grinder unit....I do not...
Here are the directions on how to clean out your grinder. Click here You will see what you are looking for in the document.
Hope I am not too late to help you. Good luck.
Mar 21, 2011 | Saeco Magic De Luxe Espresso Machine
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
We have a saeco magic deluxe maker SUP 012 that has a cracked water reservoir. We would like to order a new one. Could you please advise us? Thanks
Howdy, they don't have a central online parts distributor, but rather several physical locations throughout the states. I was able to get their customer service number, though, which may be of the best use to you.
Saeco Customer Service at 1.800.933.7876
hope this helps:)
Aug 31, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco Magic de luxe not grinding beans
Try setting the grind to the coarsest setting, if you still have the same problem, check the wire connections to the board, it might have been reversed.
May 05, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic type sup 012 problem
Hi sad_loser
Your problem is easier. On the top left side of the brew unit is a thumbscrew that holds the filter screen in the brew head. See if you push down on the thumbscrew you can get the filter screen to move? If it dose pull down on the filter screen and see if it will come out. If it does there will be an extra nut on the screw end and that needs to be removed and you need to order a new thumbscrew. That is why we call it a thumbscrew. It only has to be finger tight. The key is only for removing.
Dec 05, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe espresso machine
Ok, so you can download a new user manual for your saeco coffee machine here
let me know if you have any specific question following this.
Nov 07, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
From 1-7 on the coffee grinder, which is the finest grind.I Hve misplaced my manual
If you take of the bean hopper and the adjustment pin, then you can turn the outer ring clockwise 4 step.
Check also that the ring not is loose.
Jul 15, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic de luxe SUP 012
open the machine up and follow the line from the spout (which should give the coffee) till the boiler. The spout most likely is clogged.
Follow THIS LINK for parts etc,
Jun 01, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
559 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
