SMC EtherEZ Networking Hub Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with SMC EtherEZ Hub
I recently had to undo my computer, ethernet, and embroidery machine. when I hooked them back up I can not get it to work how many cables should be attached to my ethernet. I have an SMC EtherEZ Hub I have had it for a long time so its an older model
Anonymous
Level 2:
  • Expert 104 Answers
  • Posted on Mar 23, 2009
Anonymous
Expert
Level 2:
Answers
104
Questions
0
Helped
43663
Points
263
You can use as many as you have number of ports. example
one port goes to your broadband router, one goes to your computer, one can go to your laptop PC, one can go to your wireless AP if you have one , etcc......
1helpful
Connecting 2 computers to a SohoWare ND4025. I would like to connect two computers to this router in order for them both to use internet. The network, is set up right now, the computer im typing on...
With firewall disabled, try setting the ipv4 properties of your connection as follows: ip address:
obtain an ip address automatically.
DNS
Obtain DNS server address automatically
since this is a peer to peer network you have to understand that the two machines are independent of each other so if this is not the settings on your first machine, please duplicate the exact settings of the first machine on the second machine. The hub might be distributing specific requirements from the modem. Hope this helps
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
1helpful
2answers
How do you hook up a Dynex Ethernet Hub
If your hub has 4 or 5 connectors, connect one port to your router. This device will NOT work when connected to your cable modem, as the hub does not manage IP addresses like a router does. Hope this helps ... the remaining ports will feed internet, but not provide Internet addresses to a computer.
SMC Barricade wireless router needs to be reset constantly
Maybe it is an electricity problem, or it's nearing the end of it's life. I bought 2 routers till now.each one worked fine for 2 years and then never worked.You should buy a new one or check if there's something with the electricity . Maybe a higher voltage
Canceling a transmission after I have sent it to the sewing machine
Start from the beginning and get the machine ready for embroidery. I found I had not put the feed dogs down when it happened to me
1helpful
SMC ethernz problem
Typically you will connect your router to port 1 of the switch. Unless you have a port that is labeled WAN or Uplink. Then you would use that.
Daisy chain is when you have multiple switches connected to eachother. So it would be router to port 1 computers on ports 2-15, port 16 would connect to port 1 on another switch, and so on.
2answers
Hooking ethernet to broadband router and cable modem
Hi Sherry - The etherport port on your modem should be connected to the WAN port on your router. You then connect your pc to one of the 4 ethernet ports on the router. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Broad band hub
donn't connect the cable driect you use the 5port or 8port swicth then take a cble to modem to that swicth then how many computer you have to connect you can
ASOUNDX AL1600-D 16-Port 10/100Mbps Ethernet Switching Hub adapter
only thing you need to get a 3.3v adapter. your hub will work when to turn it on.
i guess it uses 5mA.
Top SMC Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
