Question about Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35 & Nissan Maxima 00 Up
New starter and new battery truck wont start
I have a new starter and new battery installed. my fuse looks like it could possibly be blown, however im a woman so im not positive. if it is blown could that prevent my truck from not starting? it wont do anything at all except for the lights come on, I can hear the truck getting fuel but that's about it? help???
    Sergeant:
    Habit-Forming:
  • 152 Answers
If it ticks when you try to start it it's your starter and it will have to be taken out and rebuilt or you will have to purchase a new one I always have them rebuilt generally it will vary on the cost depending on the make and model I generally order my parts from eBay because parts stores have a really big mark up hope this helps Merry Christmas
Posted on Dec 07, 2017
I have the 2000 BMW 323i it wont crank and wont start and the lights are bright no pull on the battery it just wont start or crank. All fuses are good
Possible bad starter or starter solenoid, or what the other guys said as well im just giving possibilities
May 10, 2015 | BMW Cars & Trucks
So I have a 1996 Ford Taurus GL and original problem was that it just died all of a sudden while I was driving on the freeway so I've checked the fuses found some blown fuses to replace them all I've had...
Check the starter. You may have a bad selanode. Or possibly lose wires at battery or even at the starter. Any parts store can bench test the starter foe you
Nov 22, 2014 | Cars & Trucks
Why wont my mower start after replacing battery and solenoid and i tried jumping straight to starter?
sonds like bad starter especally if you jump the starter nothing happen check for blown fuse behind dash check the starter switch trace the wiring look for bear spots but i think its the starter or blown fuse
Aug 26, 2014 | Garden
1978 corvette battery hooked up backwards now wont start at all
You didn't list any details of what you tested, found, or replaced, if any. The first place that I would start is at the battery and the starter. Look for a blown in-line fuse or fuseable links. These earlier made cars were pretty simple but they were still using some polarized transistor circuits. While you are inside the fuse box (checking for blown fuses), please check for damaged diodes. I don't think your car has any but just in case. If you don't know what they are. Diodes look like a blade fuse but are black and have an arrow on the top of it. If you write back please clarify your description. I don't know if you mean to say that your car will start and run if you by-pass the ignition system. Sending voltage the wrong way can damage so many parts. It can fry the alternator, the ignition control module, wiring, in-line fuses, fuses, diodes, and the radio. This repair will take some time. Please let me know if I can answer anymore questions. Please be as specific and detailed as you can, Good luck.
Mar 15, 2014 | 1980 Chevrolet Corvette
New maxi fuse new starter new battery dash lights up but car wont start
What about battery cables you maybe getting enough pawer for lights but not enough to start
Mar 10, 2014 | 1996 Kia Sportage
1996 dodge ram 1500 wont start it has a new starter and battery.
I would check the under hood fuse distribution box their should be a fuse that controls the starter or possibly be a starter relay
Mar 17, 2013 | 1996 Dodge Ram 1500 Club Cab
1993 volkswagon passat VR6 wont start
Sounds like a blown fuse or wiring problem.
A mechanic would check to see if the starter will crank with power direct from the battery, then look for power to the starter from the key switch.
Jul 12, 2012 | Cars & Trucks
My 1996 avalon won't start. The lights, horn, and radio work fine. Is it possible that the starter relay fuse is blown?
Battery could be old/weak/defective. Check relay/fuse box around the drivers side under the hood. Look for blown fuse (you can see easily).
Think about corroded battery terminals and especially cables. Very common. Cables may look ok, but may be oxidized and corroded on inside. They let enough current pass for radio, etc, but can't pass all the current the starter requires
Sep 18, 2010 | 1996 Toyota Avalon
2004 A 8L won"t start
starter wont click because there's not enough "juice" to turn it over. this isnt because of the battery as you have just replaced it. it is due to a bad alternator recharging the battery as you drive. if it were only a fuse it would be the solenoid in the starter. but if it had started after you installed the battery then its not the solenoid. solution: buy a refurbished alternator and
Apr 24, 2009 | 2004 Audi A8
Not starting replaced alt,starter,solenoid,and battery is good
It sounds like the wires from the battery to the starter solinoid are burned out, possibly even more of them to the main fuse box under the hood. You will have to start looking for the burned wires you can already smell and replace them. Starter and Battery area are a good place to start.
Dec 12, 2008 | 2002 Ford F150 Regular Cab
Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35 & Nissan Maxima 00 Up Logo
Top Pro-Fit Car Audio & Video Experts
Marvin
Marvin
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
