FixYa.com
Tags:
Fuji FinePix A345 Digital Camera
Card Error
posted by azza007 on Aug 20, 2007
We used are finepix A345 last saturday night and it was working fine. Today went to load the pictures onto my computer using the cable and it kept saying card error on the camera. Whats going on?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 20, 2007
FixYa! (100)
Benimur
Rank:Guru Guru
Rating: 87%, 2148 votes
On another brand/model, PC message "card error" indicates a problem with the memory card of the camera.
A couple of things we tried to restore it:
1. Remove the memory card, wipe clean especially the gold contacts making sure that it is dry and shiny (also the battery if possible);
2. Blow into the opening/slot where the memory is inserted to remove any dust, dirt or even a bit moisture;
3. Let the camera and removed memory card sit for a while at room temperature;
4. Put everything back and try again;
5. If it still doesn't work, it is possible that for some unknown reasons, the memory card was corrupted. This would mean re-formatting it but of course that would mean erasing whatever pictures and/or data are stored inside;
6. Try a recovery software with a card reader to try and recover whatever is possible and format the card;
7. It is preferable to format the card using the camera rather than the PC;
Sometimes just removing and reinserting the card works.
Hope the above gives you an idea or two. Pls post back how things are or if you need further information.
Good luck and kind regards.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Digital Cameras problems?
White Screen
My screen on my camera is... Answer This...
Fujifilm Finepix A345
Hi there, My camera works well... Answer This...
pictures not clear
Hi. The pictures in my camera... Answer This...
Card Error on Fuji Finepix A345
Just bought a new XD card. Did... Answer This...
Fugi a345
I replaced batteries 3 times... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
