Question about Mitsubishi WS-55413 55" Rear Projection HDTV-Ready Television
NEED HELP !!! :)
We just got a TV from my uncle today, it's a Mitsubishi WS-55413, rear projection HDTV. He had it set up as a HD, but we don't yet. Not sure if this makes any difference, but now the damn thing won't work. Even on the DVD player. We tried everything imaginable. The only thing we got in the whole process (besides a black screen) was a picture that was so unstable you can't make it out. It jumps around and goes side-to-side. It was working FINE today at his house. ARGH. We tried hooking the damn thing up using both antennas (A & B) and used the input slots. I can't figure out if something happened during the two block commute or if we are complete idiots. The fact that the DVD player does the same thing worries me though. Thanks for your help........Stephanie
  • 149 Answers
Hi there, there's a lose or cold solder on the board. try to see the board for some cold solder and lose connection, ty
Posted on Jan 01, 2008
SOURCE:
Its a mitsubishi ws-55413 projection tv. the tv stopped receiving the remote funtions.
Have the remote tested alone--all shops can do this and if it tests good suspect the remote receiver in the set (usually is dead center behind the screen in the middle above the lens.
May 19, 2012 | Mitsubishi WS-55413 55" Rear Projection...
My 55413 flashes from black screen to normal. It
Howdy,
The control buttons may be getting stuck. Try this:
1. Remove front speaker grill
2. Disconnect the two cables that are sticking out of the top of the inner cover. The TV will still work with remote. If that helps replace switches, control board not available. Part Number 432P109010 quanity 9.
Hope this helps, big IRISH.
Jan 02, 2010 | Mitsubishi WS-55413 55" Rear Projection...
Mitsubishi WS 55413. Ongoing rolling screen.
First check for the coolant/fluid leakage from the picture tube on to the signal board. Wipe it with paper towel and dry it will the hair dryer. I hope there's no corrosion yet.
Dec 28, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55413 timer light flashing. tv will not power on
you have some caps that have failed in the dm module
that will have to be replaced to correct the problem
if your know how to change them and have the tools the caps can be obtained through most electroinc parts suppliers
there 1000mfd 16v we increase working voltage to 35WV
if you can change them let me know and i can give you locations on the board and the dm stands on the right side of chassis at rear
Oct 24, 2009 | Mitsubishi WS-55413 55" Rear Projection...
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi projection TV WS - 55413
any flashing LED's when running service mode or convergence signal?
Apr 27, 2008 | Mitsubishi WS-55513 55" Rear Projection...
TV wont stay on
you may have a convergence problum if your convergence ic,s are shorted, you will need to check the convergence fuses in the power supply.
May 06, 2007 | Mitsubishi WS-55413 55" Rear Projection...
Mitsubishi WS-55413 55" Rear Projection HDTV-Ready Television Logo
145 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
