Question about Whirlpool MH7140XF Microwave Oven
Lights occasionaly flicker, panel intermittent
Looking for help, nothing seems or appears to be burnt on the board. intermittent operation, but dead right now.
  • Whirlpool Master
  • 9,098 Answers
So it's dead, but sometimes the inside lights come on? Does the display come and go, too? If so, and power is getting to the board, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Full information on our service is available at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 28, 2007
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
Jul 10, 2015 | LG LMV1813ST Microwave Oven
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE JE1860SH04 cabinet mounted microwave oven. Intermittently, what appears to be sparks appear behind a platic cover in the right hand side panel. I think behind this panel is the magnatron,...
there should be a way to access the area to look at it closer,probably will be able to see some kind of flash mark{black burnt look} were it has been sparking.this should give you an idea of what the problem is.guessing it"s a wire coating problem or short
Oct 11, 2010 | GE Microwave Ovens
Ge Over The Range Microwave Oven JVM2050...5 yrs. digital clock working so there's power. inside light out and basically digital key pad seems dead.. we had a few flickers of light and a brief turn of...
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 18, 2010 | GE JVM2050 Microwave Oven
My GE Built-in microwave model JVM1870 appears to have died
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download GE owner's manuals and installation instructions here to make that easier.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 16, 2008 | GE JVM1870 Microwave Oven
Can't figure out what wrong
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
Aug 20, 2008 | Kenmore 62702 Microwave Oven
Kenmore over the range microwave quit working 665.61639100
My bet is that the unit overheated and the magnetron is equipped with a thermal cutout (TCO or thermal fuse) and it blew,
protecting the magnetron.
If it runs dry, it will overheat.
But a microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If you do end up needing to take it down from the wall, you can download GE owner's manuals and installation instructions here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Microwave Ovens
No Lights just turned off
Chances are the magnetron overheated and the blew the thermal cutout (TCO or thermal fuse), thus protecting the magnetron.
Bacon has a fairly low moisture level and when can cause overheating if there's no water load in the oven.
That said, a microwave can be dead for many reasons.
Jul 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped nothing works fan lights buttons over counter ge spacemaker model jvm1630
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 19, 2008 | Microwave Ovens
Have ac power. Nothing lights up or responds.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Jun 08, 2008 | GE Microwave Ovens
Whirlpool MH7140XF Microwave Oven Logo
106 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
