The hold key on mp3 player is moving up and down, but will no longer turn off hold. Player will come on, but tells you to turn off hold , but side switch not working
If the switch is not working, your player is done - there is no such thing as repairing a problem like that - call Sony and see if you are still in-warranty. Here is a help page for your device: http://esupport.sony.com/US/perl/model-faq.pl?mdl=NWZE436F
3. Install the software on your computer, then run it.
4. Reset your player by either pressing the reset button or removing the AA-battery from the player. 5. While holding down the "Play" key on your player, connect it to the PC via the USB cable. Release the "Play" key when you see the progress bar moving and "initializing" text. If you cannot see the "initializing" text, please disconnect your player and try again. 6. Click the "Start" button to upgrade your player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first.On most models, restart is done by holding the power button in for 15 seconds or longer.Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer. -Tha Mp3 Doctor
Wrong section, BUT: The volume + key is on the side of your player - read your manual for the diagram - also, turn your player OFF first, THEN press the volume + key
you need to go under settings then click on usb modes then change the mode to msc. if you dont have the option of usb mode, then do the following: 1) Download the sansa firmware updater from the sandisk website (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe). 2) The program then turn off your sansa. (unplug it first). 3) Now move the hold button to the right and then hold down the center (round) button and then the power button. 4) Once your sansa is on, you can stop pressing the other buttons. 5) Now plug in your sansa. 6) Once this is done, your firmware updater should automatically start. If it doesn't, go to C:\programfiles\sandisk\.... and open it. 7) Select the most recent firmware and download it (it should automatically install). 8) Once this is done, disconnect your mp3 player (your firmware will then update). 9) Turn your mp3 player off. 10) Turn your mp3 player on. 11) go to Settings, USB Settings, and select MSC. 12) plug your MP3 player back into your computer and it should now recognize it.
You have locked the keys, look for a switch with a red , white or orange lock icon and move it then try to turn it on. The switch should be on the side of the player, either at the top, bottom or sides of the screen.
Probably needs replacing, but you can try these common software fixes
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer. -Tha Mp3 Doctor
you should propbably check if you have it in hold if not you should try to format your mp3, you format the mp3 by going in to MY COMPUTER then you right click on your mp3 player drive then it desplays a tool bar click on formatthis errases all music,photos,and videos in the mp3.
