Question about Siemens SpeedStream 2624 Router (936-2624-001 kit)
Siemens Speedstream 2624
I just got Comcast High Speed and I can connect directly, but not through my router.
    Scholar:
  • 76 Answers
Find the reset button on the rear panel of the wireless device and follow the factory reset instructions below: 1. Power Off the router. 2. Hold the Reset Button down while you Power On the router. 3. Continue holding the Reset Button until the Status (Red) LED blinks TWICE. 4. Release the Reset Button. The factory default configuration has now been restored, and the Router is ready for use. The DSL/Cable Router's default IP Address is 192.168.254.254 To establish a connection from your PC to the DSL/Cable Router: 1. After installing the DSL/Cable Router in your LAN, start your PC. If your PC is already running, restart it. 2. Start your Web browser. 3. In the Address box, enter "HTTP://" and the IP Address of the DSL/Cable Router, as in this example, which uses the DSL/Cable Router's default IP Address: HTTP://192.168.254.254 The first time you connect to the DSL/Cable Router, the Setup Wizard will run automatically. (The Setup Wizard will also run if the Router's default settings are restored.) This should get you in the right direction. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 20, 2007
  • Anonymous Aug 20, 2007
    If the above still doesn't work, then do this:
    1) Power down the wireless router
    2) Power down the Comcast cable box
    3) Wait 2 minutes.
    4) Power up the Comcast cable box and wait till the Ready or Wan light is stable (or just wait 2 minutes)
    5) Power up the wireless router and wait another 2 minutes
    6) Connect a PC to the router via a wired connection, wait 45 seconds and try to browse the internet.
    ZT3000
SOURCE:
My siemens speedstream 2623 router needs software disks that come
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 10, 2010 | Siemens SpeedStream 2624 Router...
How can i find my network key for siemens router. I am trying to add my work computer to my home network.
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Dec 23, 2009 | Siemens SpeedStream 2624 Router...
Will there be any problem with a Speedstream 2624 router if I upgrade to Windows 7? My two computers now use XP/3 and Vista with no problems of access. Thanks.
Hi! There will be a problem with the wireless connection. I suggest before you go to windows 7, check at your router website if there is a new update for the firmware for windows 7.
Nov 21, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
How do I connect the SS2624 to HughesNet
Are you trying to set up the router for the first time.
Make sure that the computer is able to go online when connected directly to the modem.
Click Here for more info about router set up. YOU can follow the direction for the DSL connection
Oct 08, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Missing usename/password for siemens speedstream ss2624 router
press the small reset button on the back of the unit. It will remove any security settings and allow you to use it
Aug 30, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Pvc selection keeps changing to dial up mode
  • delete the dial up connection on the internet option
  • click tools-internet options on the internet explorer - click connections tab, delete all dial up on the box, and select never dial a connection
Aug 04, 2009 | Siemens SpeedStream 2624 Router...
Siemens speedstream 2624
you have to configer your router are you using dsl or cabel inter net
cabel you dont need to set in log on but dsl you do
secound configer your router wireless i think you are are useing dsl speed stream bell use
Aug 15, 2008 | Siemens SpeedStream 2624 Router...
Speedstream router 2623 doesn't work
it could be possible that the router is just not in sync with the modem. you can try to power cycle the devices first by turning them off. then turn on your modem first, wait for all the necessary lights to turn on, then the router and then the computers. check if you'll be able to connect to the internet again. if not, you may need to access the router's page to check if it's properly configured or not.
hope this'll help you and just ask me if you'll have other concern
ciao!
Jul 10, 2008 | Siemens SpeedStream 2624 Router...
Wireless connection
messege me on aim for me to walk your through step by step. Copter64
Jan 09, 2008 | Siemens SpeedStream 2624 Router...
Where Can I Get a Users Manual Thanks for any help. Larry
Easily done!
http://tinyurl.com/3dmnea
Most all Siemens manuals can also be downloaded from the Siemens site too...
On this site, you will have to join to download, but it is free...
Good Luck!
Dec 05, 2007 | Siemens SpeedStream 2624 Router...
Siemens SpeedStream 2624 Router (936-2624-001 kit) Logo
518 people viewed this question
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
