Question about GE Profile Harmony DPGT750EC Electric Dryer
The diagnostics say there is nothing wrong with my dryer but...
The diagnostics say there is nothing wrong with my dryer, but it will not blow air out of the back of the dryer. I have taken apart the vent and it is not clogged. Do you have any idea what I can do now?
  • 5 more comments
  • MissMichelle Aug 20, 2007
    Sorry, I forgot to say this is a GE Profile Harmony Dryer, Model # DPGT750EC1PL.
  • MissMichelle Aug 21, 2007
    Absolutely up for anything at this point. According to GE the problem is not under warranty. Today, the blower is actually working. So I am really confused. But, it is running really hot even on the lowest temperature. And the service mode is still showing no problems with my unit. I did both of the tests by pressing help, then holding my cycles and back at the same time, and start/stop and help at the same time. The Electric LQC Test is how have been able to determine when the blower is working and when it is not. The temp is running between 286 and 386. There is something on it called Inlet THD: 167F (when the unit is not running and changes by a degree or 2 periodically), Outlet THD: 109F (when the unit is not running and changes by a degree or 2 periodically), Mositure: 4.92, Input (V): 60, Memory: ok, Com Data: ok. I will go and ohm the inverter board and get back with you on that status. Thanks so much for your help. I am so grateful! I am game for anything to fix this dryer.
    By testing the wire I read: Blue 15.1, Red 15.0 to 15.1, Yellow 15.1 also. Is this good? This is higher than the 14.
    Correction to the Temp on the dryer. It is the INLET THD that is running between 286-386. The heating just says ok. No temp is displayed.
  • MissMichelle Aug 22, 2007
    Okay, thanks for the vote of confidence. But it was soley by your great information that I was able to check the ohms. I am deffinitely not afraid to try figure things out! Would you please tell me where the thermistors are and what they look like so I can test these? If these are going bad, what do you do to replace them? Are the thermisters the little plugs inside the lint trap?
  • MissMichelle Aug 26, 2007
    I found the outlet thermostat and with the multi meter it shows no reading, is this normal? Would the thermostat show a reading? The outlet thermistor shows 12.17.
    Yes it works when it wants to and doesn't when it doesn't. That is why when I was checking the Outlet thermistor, I also checked the Outlet Thermostat next to it. The outlet Thermister registered ohms, but the thermistat did not. Is the thermistat suppose to process ohms through it when I use the multi meter? Could it be this thermostat? Would that make the blower stop?
    President:
  • 878 Answers
Michelle, So the drum turns but no venting out the back? This model has a DC motor for the vent, but if it failed, Im surprised that you did not receive an error message. Did you run the service mode? Power on, then press the home key, then help key. Then press the my cycles and back together for 3 seconds. Any error codes should now be displayed. The more icon will be displayed if there are more than 1 error. If you still are not getting an error you can ohm out the blower motor. There should be a 10 pin harness on the inverter board under the consol. The blower motor has the approx. resistance value of 14 ohms between yellow to yellow, red to red and blue to blue. The next step would to be to do some tests on the inverter board. Let me know if you are up to that. Catriver.
Posted on Aug 20, 2007
  • 3 more comments
  • Ron Marek
    Ron Marek Aug 22, 2007
    Michelle, lets go after the thermistors. On this dryer, if the outlet thermistor is out of range the control board will limit the heater to 60% of it's power. If the inlet thermistor is out of range the board will default to using the inlet thermostat to cycle the heater on and off. The inlet thermistor should ohm out at 2.27 K ohms. The outlet thermistor should ohm at 10K ohms. Sounds like the blower motor is good according to your readings. Sounds like you really know your stuff. Good work, let me know how it is going...Catriver.
  • Ron Marek
    PS Michelle, these thermistors can be out of range and the board can fail to give an error on them.
  • Ron Marek
    Michelle, let's see if I can attach a photo of this dryer. The inlet thermistor can be accessed from the rear of the dryer. It will have a cover on it. The outlet thermistor is located on the blower housing next to the thermostat. You will have to remove the top, front and drum to access it. I hope you can enlarge this photo, it will give you a good idea. Catriver.
  • Ron Marek
    Ron Marek Aug 26, 2007
    Michelle, the outlet thermostat is located on the blower housing. If it reaches a temp beyond it's maximum rating it will trip and disable the heating function only. This thermostat is resetable. Should trip at about 190 degrees and reset at approx 150. A few degrees either way, no big deal. If you found it open, the unit should not heat at all until it resets. Are you still having problems with the blower not working? The themistor sounds like it's in range. Catriver.
  • Ron Marek
    No, the only function it will stop is the heater, whether gas or electric. It will not affect the blower. The fact that the blower motor ohmed out ok, leads me to believe the sporatic problem is in the inverter board. The only thing that is going to stop the blower from working is, the blower motor itself, the safety thermostat (which will kill all functions of the dryer) and the inverter board. Im sorry if I confused you with thermistors and things. I went from blower motor problem to heating problems..of which, I don't know why. Catriver.
SOURCE:
Tumble dryer isblowing cold air only?
Your dryer is called smart dryer and in this case should have to generate familiy code E60 (or any of exactly fault code E61,62,63,64,65,66,67) if blowing cold air, as you explain. Means something is wrong with heating phase (drying).
So, in this case could be: Heater unit faulty; Wiring faulty; NTC sensor faulty/out of position; Electronic board faulty;
Thermostat faulty; and finally fun motor - but considering that it blows cool air I guess that is correct.
24642590-hf2jxxovvq5cn05mugly0fcq-2-0.jpg Dado
Jun 16, 2014 | AEG T58840 Dryer Electric
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
My dryer's vent is clear but blows no air out the back of the dryer and we just replaced the dryer belt and help with this
check the blower fan on inside of dryer. it sounds like something is wrong with it. this fan is where the dryer gets the air to blow it out threw vent pipe to outside. good-day !
Jan 28, 2012 | Dryers
The drum is turning but it's blowing cold air, no hot air not even warm. The last time it was used it was hotter than usual, but now nothing.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Aug 04, 2011 | Dryers
Please help...i have a brand new whirlpool dryer mod #wed9450wwh and it takes forever to dry a load of clothes...a small load or a large load. i have tried every setting and bought a new dryer...
Check the vent cap on the outside of your home to see what the air flow is like when the machine is on. It should be forceful enough to blow your haire back if you were to put your face in front of it. Make sure the vent hose behind the dryer is as short as possible and is not pinched or coiled. This definitely sounds like an air flow issue.
Kelly
Mar 21, 2011 | Whirlpool GEW9250 Electric Dryer
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Won't Dry
Try taking off the duct from the dryer, it has to be something blocking the air flow, check if the end of the dryer is trowing out air, if it is not, then you have to take it apart to see if there is an obstruction inside of it
Dec 17, 2007 | Kenmore 62872 Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
150 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
gbob59
Are you a GE Dryer Expert? Answer questions, earn points and help others
