Question about Epson Stylus CX4600 All-In-One InkJet Printer
Printer will not print color
I have left my Epson stylus CX4600 unused for the better part of two years. When I went to use it I found out that my roommate had taken the ink cartridges out and it had been sitting empty all that time. I've put in new ink and I've tried running it through but aside from the black which is a little scratchy none of the colors are working. I've cleaned the print head several times and left it over night with no improvement, is there anything else that I could do?
  • Anonymous Nov 04, 2007
    Color has not been used. The printer has brand new cartridges now and it will not print color or black.
  • shiffie Dec 08, 2007
    I have left my 4600 unused for a year and it won't print at all. I've turned it on, ALL the lights are on and I'm unable to select what I want.
First off ( I know it's too late for you but for others ) NEVER turn off your printer it stays warm when on and keeps the ink from drying up and turning into cement in the nozzles.
I had this problem before and first used lighter fluid in the nozzles. This freed them up a bit but still was not back to normal so I then sprayed some wd-40 in the nozzles and after printing out all the crap it was back to normal 100%.
I know this sounds quite unusual but if it works don't knock it.
Kevin.
Posted on Nov 08, 2007
Maybe a drop of water in each nozzle to try and lossen things up? I dont know just a thought, sounds like it may be a lost cause anyways, so it may be worth a shot.
Posted on Aug 22, 2007
SOURCE:
Epson stylus cx4600, not working
the printer wont work it will copy but not print anything off computer
Feb 01, 2010 | Epson Stylus CX4600 All-In-One InkJet...
The ink does not flow after replacing cartridges. The printer was unused for a long time
Throw away the old cartridges and purchase Epson Genuine Cartridges.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
Good Luck.
Jan 19, 2010 | Epson Stylus RX500 All-In-One InkJet...
I use new remanufactured epson replacement cartridges for my epson stylus nx400. have been doing it wth no problems for a year. left printer idle for 2 mths. tried to print in color and the colors come out...
2Mths is a long time to leave an inkjet unused and it may take several head cleans to clear and blockage (caused by dried ink) A test page will show if and when the heads are clear.
Oct 18, 2009 | Epson Stylus NX400 InkJet Printer
Epson CX4600 printer - will not print color at all
no it should work at it is. if you installed the plug and play printer driver. have you removed the protection tape from the inc tubes?
Oct 12, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Lines in picture when printing
In the print queue there is an advanced tab that takes you to see how much ink you have etc. Go to the maintenance tab and select the cleaning option. Be aware that this uses up a lot of ink doing this. But once you have done it check the nozzle printout to see that it is continuous in its printing on all colors. keep at it till it is.
To prevent this from happening in future keep the printer on Epson dont say that turning it off can cause the ink to solidify in colder weather.
I have come to leaving mibe on 24 hrs a day or taking the cartridges out and then printing a pic till all color is used fromj the reservoir. This has kept my EPSON 90 going for 10 years my Epson A3 died within 3 years from clogged jets
Sep 01, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Printer is not printing text
If the printer was unused for a week or 2 the print heads are clogged with dried up ink. You can use the maintainance tab for the printer for cleaning and nozzle check or the program below. I have been using it for several years.
This is a utility to manage your ink. Gives an accurate count of how many ink shot are left in each cartridge. The printer just told me I need a new magenta but this program says I have 13% left. It also has sepparate routines for cleaning the black and color (unfortunately not individual cartridges) and a powerful clean cycle when they are really cogged.
http://www.ssclg.com/epsone.shtml
Jul 17, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson Tylus CX4600 ink light
If any ink cartridge is empty, you won't be able to print until you replace the empty cartridge. Leave any empty cartridge installed in the device until you have obtained a replacement.
The print heads will clog up in a week or two. So you also won't be able to print until you clean the print heads.
This is a utility to manage your ink. Gives an accurate count of how many ink shots are left in each cartridge. The printer told me I need a new magenta but this program says I have 13% left. It also has separate routines for cleaning the black and color (unfortunately not individual cartridges)
May 18, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 all in one printer, scanner
Under Maintainance in the properties of the printer it gives you the option to clean the print heads. Should work
Feb 19, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
129 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
