Question about JVC Arsenal KD-AR560 CD Player
Subwoofer instalation Hello, i have recently installed my jvc. I have a subwoofer that i want to install, the only problem is that the jack on the manual that says subwoofer is just an empty space where a jack should be on my jvc. I was wondering if i needed to buy an upgraded system that will recieve the subwoofer, or if i am suposed to install the jack myself by removing the back plate. thankyou, josh
I have a passive sub for my pioneer home stereo how do i hook it up, do i load down the front or rear speakers? pleas help
Posted on Dec 13, 2007
    Problem Solver:
  • 6 Answers
Even if your JVC doesn't have outputs for a subwoofer you can hook it up with the a speaker wire to RCA converter. You just spice your rear speaker wires to this device then connect RCA's to your amp. I've used them before... works great. http://cgi.ebay.com/ebaymotors/Speaker-to-RCA-Line-Level-Converter-Adjustable-High-Low_W0QQitemZ130143832174QQihZ003QQcategoryZ38636QQcmdZViewItem
Posted on Aug 20, 2007
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
How do preset a station on the jvc kdg230?
Hello... I am sorry you are having a problem. The correct procedure to store radio stations on this headunit is as follows:
- tune the headunit to the station you want to save
- press a the button 1-6 under the display that you want to store the station to and hold it for 2-3 seconds.
- it will store the station to this number
Hope this helps!!
20 year car audio/video installer
Bay manager
Mar 17, 2011 | JVC Car Audio & Video
How to install an amp on a jvc kd-avx77
How do I install a set or a sub to this head unit with only one wire output marked sub,I'm not sure if may amp will play correct.
Dec 03, 2010 | JVC Car Audio & Video
Jvc kd-g340 rear speakers not working. I recently bought the car with this unit installed. I noticed that there is a l/r cable, power, ground in the trunk which means there was probably a subwoofer...
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Mar 31, 2010 | JVC KD-G340 Car CD/ MP3 Player
INSTALLING CAR STEREO IN CAR
Metra part numbers Kit 99-4500 harness 70-1858 ant adapter 40gm10
Aug 13, 2009 | JVC Car Audio & Video
Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Jun 06, 2009 | JVC KW-AVX800 CD Player
No sound from sub woofer---just humming sound when turned up
Make Sure you have connected properly. If you purchase the speakers from DELL, Click here download the manuals.
Thanks, PREM
Mar 28, 2009 | Dell Dimension 2400 PC Desktop
Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Feb 10, 2008 | Pioneer VSX-505S Receiver
Cable to plug into computer
Hello there
First things first:
1) Go to the HK page, and try their support area. or email them.
2) On Radio Shack, you can bring the jacks for a replacement.
3) install the new jacks! according to the HK model.
good luck
Jan 24, 2008 | Harman Kardon SoundSticks II Computer...
JVC Arsenal KD-AR560 CD Player Logo
307 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
