Question about GE 46GW945 46" Rear Projection Television
Hour Glass!!! I still have have a picture on it but, the image has like 3 rotating portals in the middle and both ends. All three colors are out of alignment. Very little money, is their a way to fix it myself???
  • Mellod Aug 20, 2007
    I repair laptops part-time for a living so, I'm sure with help I can get it done. Please just let me know what I need!!! I have a soldering iron and not afraid to use it!!! ha ha
    Genius:
  • 1,153 Answers
Pinchusion problems, you need to know about components and soldering. If not then you need qualified tech.
Posted on Aug 20, 2007
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Hello, I have a mitsubishi ws-65907, It has
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Bowed picture colors off
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Nov 02, 2009 | Mitsubishi WT-46807 46" Rear Projection...
My mitsubishi WS-55859 picture is not as clear as it should be and there are horizontal lines across the middle 1/3 of the screen. I also notice a green ghosting on some images and some colors. Any ideas?...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 13, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Color ghosting or shadows
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
MITS WS-65869 The green CRT is creating a warped image.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV may have one or more of the following symptoms....
Dec 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
After replacing the convergence the three colors are still not aligned
there should be a menu button on the tv itself go to picture setting and reset all three colors to the middle. if that doesn't work then you'll need a new regulator for the convergance which is about 25-50 dollars
Oct 22, 2008 | Sony KP-57WS500 57" Rear Projection...
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
3 images in different colors-42 in Sony projection
So this is a rear projection TV.
Chances are the tubes are out of alignment. When cleaning or anything never move the tubes as it will be hell to get em back properly.
In the back you can take off the rear panel and move the tubes to partially re-align the picture.
This is generally followed by a model specific procedure using the remote to bring up alignment grids to finalize the picture alignment.
The reason for the 3 colours in the picture are that the rear projection units use Red, Green and Blue tubes to create the one colour picture.
All in all... When I messed mine up it took about 2 hours to set it straight again.
Now I just have to fix my flashing screen problem and i'm set.
Feb 16, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
29 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
