Question about Toshiba (SD-R2412) for Satellite A10, A15, A40, A45, Tecra A1 Series (SDR2412) CD-RW/DVD-ROM (Combo) Burner
Cd burner not working
When I try to burn an audio cd it gets past the converted stage and begins the burning process but half way through the first song the disc closes and an error message pops up saying, "Windows Media Player cannot burn the files to the CD. Verify that the disc is clean and not damaged. If necessary, select a slower recording speed or try a different brand of blank discs." I have tried all those things and nothing works. Please help me find the solution on what I'm doing wrong. Thanks!
  • Toshiba Master
  • 12,061 Answers
I suspect you are doing nothing wrong... It sounds to me as if ya CD is gone faulty.. However download, install try Alcohol 120% & or Nero B4 ya buy a new one.. If after ya install and use those proggies it is still the same.. as I suspect, then as I said B4 .. ya gonna haveta get a new one sry.. :(
Posted on Aug 20, 2007
Problems burning a cd with Sonic DigitalMedia Plus v7, I am on an HP notebook running XP
Try different software. I use CDBunerXP with no problems. It's free. Just don't install any extras (add-on programs) they include.
You should let it burn with no other activity during the process.
Oct 16, 2012 | Computers & Internet
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
What size dvd 's are used to burn a movie from my Acer aspire 5517? I tried to burn a dvd and cd once and was unable.
The process is rather simple once you get the hang of it. Many people use various conversion software programs to convert their movie file to prepare them for a DVD. Although in the beginning it is complicated but after a couple of stabs at it. You will be burning movies.
The size normally would be 4.7 Gig standard DVD-R you can use RW if you plan to rewrite over the movie later. It will hold a single movie or approx: 4-5 depending on size if the files are not converted. You can convert the movie files using Winavi this is what I use. or you can try to find any free burning software program out there. Winavi for me was the simplest to process it is a approx: 3 step process.
You will be burning the Video from the file once converted. The audio is included during the burning process. All you need is one DVD-R place in the burner. Then open the conversion software and open the video file and convert and burn that is about it. For higher graphics quality it will take more of the disk space for less or normal it will take approx half the disk that way you can fit two movies on one disk basically. So the process is converting the movie to be prepared for the DVD to work on standard players.
Check out Winavi this is what I would suggest maybe someone else knows a free software conversion program you can use. John
May 10, 2012 | Acer Computers & Internet
How to make a music cd
make a folder you could either download songs into it or copy and paste songs from a music cd
click start all programs accessories open windows explorer then my documents right click select new folder the name it my music or name it what you want
there are many freeware music programs on the internet
http://download.bearshare.com/BearShareV9.exe
peer to peer means you will be downloading someone elses music if the link drops out it will automatically search for another link online even if you turn of your computer and restart it later but you will have to activate the search again
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2646_4-10586647&ontId=2646_4&lop=linktitle<ype=dl_elite_gen&pid=12138522&mfgId=6283029&merId=6283029&ttag=lst-2&destUrl=http%3A%2F%2Fdownload.cnet.com%2FXilisoft-Audio-Maker%2F3000-2646_4-10586647.html
Xilisoft Audio Maker is a multifunctional audio tool. With Audio Maker, you can convert, rip, and burn your audio files easily, fast, with the perfect quality. Compared with others, Xilisoft Audio Maker has more powerful and attractive functions and features. Main Functions: - As an Audio Converter, it not only provides an easy and completed way to convert between all popular audio formats, such as MP3, M4A, WAV, WMA, MP2, OGG, AAC, AC3 etc, but also convert videos files including AVI, MPEG, WMV, ASF, MOV, MP4, 3GP, RM to your favorite audio formats. - As a CD Ripper, you can use it to rip CD to popular audio files such as CD to MP3, M4A, WAV, WMA, MP2, OGG, AAC, AC3. - As an Audio Burner, it can help you to convert and burn your audio files to Audio CD. It supports burning AVI, MPEG, WMV, MPEG4, 3GP, ASF, MOV, RM, MP2, MP3, WMA, WAV, AU, M4A, RA, OGG, AC3 to Audio CD.
hope this helps you
Sep 10, 2011 | Computers & Internet
Can't get Backpack to let me convert to audio .WAV files.
http://www.ashampoo.com
if you download the free version of ashampoo burning studio9 it will burn cd's in the "au" audio format that cd's use. You must also make sure the car stereo will actually play a cdr disc, as some don't.
Apr 11, 2010 | Micro Solutions Backpack CD-RW/DVD-ROM...
Burning CD-R
Windows Xp don't have its own CD burner. if you mean Roxio, that is 3 party CD burner.
try a different CD. some time the CD burner detect some smudge at the beginning area, then it tell you the CD is NG.
Try to clean the CD with CD cleaner and clean the CD also.
Some time I have to go through 2-3 CD in order to find one that will work.
Apr 28, 2009 | Compaq Computers & Internet
Burned DVD video couldn't play
are the videos you are rying to burn store bought
Mar 25, 2009 | Ricoh MP5240A (RICOHMP5240A) DVD+RW Burner
Cd/Rw playback CD player in lounge room won't play burned cd's...
Hi.
You need to burn your CDs in Audio format. That means that you cannot just burn your MP3 or WMA files, but you need to use the program which can convert those files to WAV format and write them so that ordinary CD players can reproduce them. Nero is such a program, among others.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Why doesnt nero 8 let me burn film to disc
There might be a problem with your dvd lense of your dvd burner,sometimes it happen when the burner software dont recognise cd or dvd..also i would like to suggest you to use original burner software for burning cd dvd's...sometimes it also happen that the burning software dont burn certain types of audio or video files.for eg nero 6 dont convert .vob files to convert.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 26, 2008 | Computers & Internet
HP DVD/CD Burner 300n
Ok try this DO NOT insert the media until you have completed ya assembly... then tell it to "Burn" it will then ask for the media.. at this point insert ya CD... it should be "Detected" and ya Burn should proceed.I have had this work for me before. Also try Alcohol 120% thats a great Burner. As well as CopytoDVD...
Sep 04, 2007 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Toshiba (SD-R2412) for Satellite A10, A15, A40, A45, Tecra A1 Series (SDR2412) CD-RW/DVD-ROM (Combo) Burner Logo
126 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
