Question about Memorex MVD2022 DVD Player
I can not find a code for my comcast remote?
Searched high and low tried everything. is this thing a repop of some other brand? how can i get a code for my comcast remote?
    Novelist:
    Scholar:
  • 158 Answers
Nip to this web page for more info on your remote control found link in forum http://www.comcast.com/corporate/customers/customer_support/remotes.html hope this works
Posted on Aug 20, 2007
Get the volume on my Comcast remote to work (new tv, everything else works, DVR, Channels etc. but not volume
Check it with set it up by an other code said to your device brand. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Nov 02, 2014 | Motorola Comcast Universal Remote Control
What is the remote code for comcast grey button remote for SONY STR DE835?
2285,2260,2263. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
Jul 16, 2014 | Xfinity NEW COMCAST HDTV DVR CABLE REMOTE...
Remote control code for a Comcast remote, Hisense LHDN32V tv, code in maual 10748 doesnt work.
here is a site that gives you all of the remote codes for your comcast remote. Scroll down to comcast and select the correct comcast model. It will show you all of the codes for everything
Good luck
http://remotes.com/store/codes_original.html
May 03, 2011 | Televison & Video
AKAI 27"LCD SN:60683669 Have HDMI connect o
Universal remote controls (like the one for your comcast cable box in which it allows you to control other devices) have "the most popular" IR codes programmed inside of it. When you type in the numbers "10812,10702, etc" you are telling the remote to use that particular IR code within its "database"
The key thing to know is that universal remotes do not have every code, just the most popular. If you have tried all of the codes listed in the manual for you model TV there's not much you can do.
  • Try searching for a code. Some brand names, such as "Akai" may have other manufacturers parts inside of it, Searching usually is done by going through certain key-presses on the remote to try all of the codes available.
  • Buy another Universal remote, not all remotes are created equal as some have mode IR codes built in than others, if you have an odd brand TV, it may be more difficult to come across one that works.
  • Buy a learning universal remote, although usually more expensive these remotes will allow you to "learn" the IR codes from your old remote to the universal remote.
I hope this helps.
Mar 06, 2011 | Akai LCT2721AD 27 in. LCD Television
No Comcast remote code
If you look at the instruction sheet for your remote under 'searching for your code' you will see:
SEARCHING FOR YOUR CODE
If your home entertainment device does
not respond to the remote control after
trying all of the codes listed for your
brand, or if your brand is not listed at all,
try searching for your code.
For example, after trying all of the
codes for your TV, you still cannot get
the remote control to operate your TV,
then:
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
first.
5. Press Setup once to lock in the
code.The TV key will blink twice.
6. To search for the codes of another
device, repeat steps 1 to 5, but
substitute the AUX key for the auxiliary
device you are searching for
Nov 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Need codes for remote control access to go with Comcast hd adapter remote. Only 2 listed with remote from Comcast: #'s11723, 12066 Comcast remote will not control TV
If you look at the instruction under 'search for your codes' it will tell you how to scan all the code until you find the one that will work. Down load the manual here for your remote:
then:
1. Turn on your TV.
release Setup.
blink twice.
first.
Nov 02, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Comcast remote cannot operate Funai/Sylvania LC225SSX tv. Tried all codes, even for all televisions made by Funai. Code search did not work. Comcast tech could not get Comcast remote to work on the Funai...
Currently there are no remotes nor any codes for them that will operate virtually any sylvania tv's. sorry, it's like the only model we have no resource for as of yet. -Comcast Tech
Jul 31, 2009 | Sylvania LC-225SL9 22 in. LCD TV
Universal remote codes
try 21086. you could also do a code search with the remote its on the comcast.com website under remote codes and do a code search.
Sep 12, 2007 | Motorola Mobility DRC800 Universal Remote...
Comcst remote control code not working
comcast dvr3 remote code for jensen sc2050j is 0150 gil_hodges@bellsouth.net
Jul 27, 2006 | Jensen TS2050J 20" TV
Memorex MVD2022 DVD Player Logo
257 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
