Drywall Logo
A
Anonymous Posted on Jun 10, 2013
How to put tape and putty on drywall - Drywall
Ron Morton
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Aug 14, 2013
Ron Morton
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
15220
Points
14
The TapeBuddy drywall taping tool is the answer to your taping problem. A one step drywall tape and joint compound application tool that makes taping easy. It's lightweight, easy to assemble and applies an even amount of joint compound directly to the joint tape. It even applies more compound to the tape center where more compound is needed. Just load with paper or Fibafuse tape and joint compound, pull out the coated tape, cut, apply to the seam and embed. There is no need to pre-mud drywall joints or carry around heavy tools. Taping walls, corners and ceilings is fast with no mess. TapeBuddy is a great DIY tool that will give you professional results. It is easy-to-use and the perfect tool for any drywall taping project.
The tool comes with easy-to-understand How To information on taping drywall. There is a how to manual on their website.
  • Ron Morton
    Ron Morton Dec 11, 2013
    TapeBuddy tools will be in the Home Hardware warehouse in January so if you have one close, you could visit your local store and ask them about ordering one for you.
  • Ron Morton Feb 06, 2014
    Jensen, I'm not sure where you are from but they do sell these tools on their website. Not sure what other materials you refer to.
Can I tape between a popcorn ceiling and a smooth drywall wall?
By beading, are you referring to drywall tape? If this is cracked and you want to repair the tape, I suggest you use a nice cove mold to cover up the lose tape. Otherwise you'll need to remove the old tape, smooth out the popcorn ceiling area, re-tape the corning then feather it in, then texture the ceiling again. The trip is much easier to do. It's cleaner, quicker and really would look nice.
Will it stick? yes but unless you want to keep the same look, I opt for the cove mold.
Nov 14, 2014 • Drywall
tip
Minor Drywall Repairs
<span>It takes about 4 days for a good patch to be made. You can buy the materials in small quantities at the hardware store, so it won't cost much at all for a small hole, and a little more for a larger one.<br /><br />For a hole smaller than a tennis ball, you can press newspaper crumpled loosely into a ball into the hole, as much as you need, to build the hole up to just below the surface, then cover with overlapping layers of drywall mesh tape. The directions for a larger hole follow, and you can skip the first parts of it if you do not need them (if you are using the newspaper method.). With this method (newspaper) the most important part is to remember that the first coat of spackling is just to anchor the tape and bridge the repair, no more.<br /><br />The easiest way to repair a larger hole in wall board:<br />1. Cut a piece of new wall board larger than the hole you want to repair.<br />2. Take your wallboard "patch and hold it over the hole. Draw the outline of the patch on the wall.<br />3. Using a drywall saw, cut out the outline of the patch on the wall.<br />4. Cut a piece of wood longer than the hole is tall, by about 4". Measure back from each end 2".<br />5. Start a drywall screw 1" above the patch outline, centered. Align the wood in the hole with the lines you made on it at 2" back from the ends. Screw the drywall screw into the wood. Do the same at the bottom. You'll want the drywall screw to be below the surface while trying not to break the paper surface of the drywall.<br />5. Fit your patching piece into the cavity, and, depending on how large the hole is screw through the patch and into the wood with one or two drywall screws.<br />5. Using self-adhesive drywall tape, tape the crack around the patch, overlapping at the corners.<br />6. Use pre-mixed drywall spackling with a 4" putty knife to apply the first coat of drywall spackling to the patch. The aim here is to secure the new drywall to the old, so you need to use the putty knife to press the spackling into the crack, and lightly coat the drywall tape. If your screws that were used to secure your wood to the back of the old drywall are outside of the tape, press the spackling into the screw dimples as well. If you hear a "ticking" sound as you pass over the screws with the spackling, the screw isn't set deep enough. Give it another turn or so, until you don't hear it tick when you pass over it with the knife. Let all of this dry for 24 hours. Clean your tools, and dry them.<br />7. The next day, sand any burrs that stick out, but sand lightly, trying to taper the patch out onto the old wall. Don't be too particular, as there is still a ways to go. Using the drywall knife and spackling, re-coat the patch, blending more onto the wall, and leaving a little more material in the mesh of the drywall tape. The cracks should be refilled, as they'll have shrunken in overnight, so this is all done at the same time. Don't over-work it, just give it a good coating, and leave it alone. The screws that you previously spackled will get another coating at this time as well. You're done for the day, clean and dry your tools.<br />8. The next day, lightly sand the burrs, again feathering a bit onto the wall. Try to remove the dust from sanding with a dry cloth, lightly brushing the patch and wall. This should be the final coat today. Lightly apply your spackling, feathering it out onto the wall. The aim here is to make the finished repair invisible to the eye, so feather out onto the wall at least the width of your blade, if possible. You can fill the screw holes again as needed, feathering the spackling out from the screw dimples onto the patch and wall. Done for the day. Clean and dry your tools.<br />9. Day 4. Sand the patch, feathering out from the patch and across the patch. It should appear relatively flat to the eye, with the cracks and screw holes filled and feathered. No tape should be sticking out. It will all appear smooth. It is ready for matching paint.<br />Hope that this was helpful.<br />Best regards, --W/D--</span>
on Feb 03, 2011 • Plumbing
tip
Fiberglass/Mesh Tape Mythe
I've heard people say many times, " When I finished the drywall on my room addition, I used Mesh Tape
www.all-wall.com/Categories/Fiberglass-Mesh-Drywall-Tape/Thin-Drywall-Mesh-Tape
on my seams and inside corners". Well, I would strongly recommend that you use Paper Tape instead:
www.all-wall.com/Categories/Drywall-Joint-Tape
along with All-Purpose Compound: www.usg.de/index.php?id=1357
Even though Fiberglass/Mesh Tape is much easier to apply than Paper Tape, you should not use it because it has a greater tendency to crack when applied to New Drywall seams; unless you use Easy Sand 45, 90, or 220.
www.lowes.com/pd_11778-325-384210_4294864808+4294851233_4294937087_?productId=3009562&Ns=p_product_prd_lis_ord_nbr'0''p_product_quantity_sold'1&pl=1&currentURL=%2Fpl_SHEETROCK%2BBrand_4294864808%2B4294851233_4294937087_%3FNs%3Dp_product_prd_lis_ord_nbr'0''p_product_quantity_sold'1
The different numbers ( 45, 90, 220) indicate the amount of time, ( in minutes), that you have to work with this material before it starts setting up on you. TIP: I would not recommend this material if you are a beginner! The consistency of this material varies as time goes on, becoming thicker and thicker.
Mesh Tape is good for many other uses though. Such as, a fracture in the drywall, patching around electrical boxes, applying to corner bead as a strengthening material, or removing old tape and re-taping old rough seams in a rehab house.
Good Luck!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power-HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Thanks for looking,
Jim
Key Words: Drywall/Sheetrock/Gypsum Wallboard
on Sep 29, 2010 • Hand Tools
How do I tape a drywall ceiling?
250' and 500' rolls of paper are basically the same price per foot. The question is listed under " How do I tape a drywall ceiling?" So let me start by saying it's easy to tape a drywall ceiling with the right tools. "The TapeBuddyĀ® drywall taping tool is a one step drywall tape and joint compound application tool that makes taping drywall SUPER Easy!" Rather than paste more TapeBuddy info here, go to tapebuddy.net for the info. The how-to manual will give you lots of great advice.
Paint bubbles on drywall
It's been almost 10 months since the question was posted so how does it look? Most bubbles appear under the drywall tape or could be from primer / paint being rolled over drywall dust. Tape bubbles don't go away. These need repaired by cutting out the bubbled tape and filling in with compound. Tape bubbles can be avoided by using a TapeBuddy taping tool. This tool applies compound directly to the tape so there are no dry spots under the tape. Hope this helps.
May 05, 2014 • Drywall
2answers
Water damage to ceiling
Cut off the loose make flat tape and drywall mud
Mar 06, 2014 • Drywall
1helpful
3answers
What can replace that tape, if i can't find it what i can use ineteat
just go to any hardware store and buy any drywall mesh tape on that width (2" - 50mm) and approximately same length (50yds to 60yds), virtually all of them have same internal diameter, therefore you should not have any problem with putting it into the dispenser.
do not bother with brandname! generic tape work as well and is half the price! tapeis glued only to tack to the wall, then mud is holding it.
Can I use a plastic putty knife to tape up dry wall?
Its not recommended that you use a plastic putty knife when working with drywall. Since the plastic ones are not made for that purpose and don't hold up as well as the metal ones that are made for drywall taping.
Sep 09, 2013 • Drywall
1helpful
Fixture for curtainrail wentthroughplasterboardbig hole now help.me fix please
Hi, W/D here.
Hole in drywall. need a cheap fix
How big is the hole? A cheap fix is this stuff called fluff, it is lightweight spackling compound, comes in a little tub, will dry hard as a rock, and stay put. You will need a knife big enough for the job, not a little putty knife but a 6 inch dry wall, depending on the size of the hole. A little mesh tape might help a big hole. Hope this helps.
May 15, 2010 • Drills
Top Drywall Experts
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
NOEL
NOEL
Are you a Drywall Expert? Answer questions, earn points and help others
