Question about Samsung SyncMaster 172N 17" LCD Monitor
Monitor the power button is flashing green, but nothing is displayed on the monitor screen
  • 1 more comment
  • Cowaz Dec 25, 2007
    I was using my computer when the screen froze, then the screen went black and the stand by button on the monitor started to blink. I restarted my computer but nothing comes up on the monitor, it remains black. Checked the connections, unpluged the monitor and plugged it back in. It's like it went into hybernation mode and won't come back up.
  • alh234 Apr 27, 2008
    it just went black! I tried rebooting - nothing. Checked it on another computer - still black! I get the green and amber power light but nothing on the screen itself - not even ghost images of trying. Did it just up and kick the bucket - it is only a few years old. Help!
    Lynn
  • rspect357 May 23, 2009
    green power light is blinking and there is no display
    Master:
    Sergeant:
  • 461 Answers
Is your monitor connected to any system? beside the power supply? Try to check the connections.. you may need to explain further of the system that you are using....
Posted on Aug 30, 2007
SOURCE:
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Green power light comes on goes off then on again stays solid, moniter says no signal, mouse lights up, and three red lights on key board flash then nothing why?
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Nov 21, 2012 | eMachines EL1852G-52W
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
My Display has nothing showing and the Power Button has a flashing green LED...Can you help?
This usually happens when there is some video resolution conflicts occurs. Try to start windows in safe mode and then making a lowest resolution applied.
If you are unable to start windows. Try removing its data cable from cpu. and check whether there is any display on the screen.
Also check its pins..
Jan 16, 2010 | Samsung SyncMaster 244T 24" LCD Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Green light just flashes on and off and there is no displ
try to check your screen resolution maybe not compatible to your System. if green flashing there no signal from cpu to VGA cable monitor.
Jun 07, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Blank Screen
Can you see anything at on but dimly? If so thats is the backlight tube If you cannot see anything then it is a major fault eitherway a repair shop job I should think
May 30, 2007 | HP L1902 19" LCD Monitor
Samsung SyncMaster 172N 17" LCD Monitor Logo
334 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
