Question about Miele Touchtronic G892 Built-in Dishwasher
Miele G892 SC dishwasher not heating/cycle won't stop
Machine is only 2 years old. Water isn't heating up and cycle continues for over 5 hours then dishes aren't clean. Had a lot of high pressure are in the line after changing out the home water heater, but don't see any conection there. The machine we have is a G892 SC and has its own heating element also. Any advise is appreciated.
  • Anonymous Mar 16, 2014
    What is the decibel level on the g892 sc dishwasher
    Problem Solver:
  • 14 Answers
Could be heater pressure switch
Posted on Sep 15, 2007
  • 51 Answers
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Posted on Aug 21, 2007
2 Suggested Answers
SOURCE:
james klgr
  • 362 Answers
SOURCE: Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Posted on Dec 09, 2007
Whirlpool built in dishwasher DU840SWKQO
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Dec 22, 2011 | Whirlpool Dishwashers
Miele G892 SC Touctronic dishwasher, intake/Drain light came on. How do I clear the drain?
Evening to you - empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check if all clear - clean up & assemble - should be good to go...
Jul 01, 2011 | Miele Dishwashers
White film on dishes and still dirty.
Check rinse aid is actually dispensing - turn it up to max for a while to clear it, and check level is going down after a week.
If you suffer with hard water - your heating element may need replacing as it is probably furred up.
Jun 06, 2010 | Miele G892SC SS Dishwasher
It leaks from the left side when washing dishes
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dddg
Nov 22, 2009 | Miele Touchtronic G892 Built-in Dishwasher
Miele Dishwasher G2170 3 year old
On the display panel of the washing machine there are a few screws on the side. Remove that panel and check for power at the computer and sensor. Also make sure that when it is one and calling for water that it is getting everything everywhere
Feb 14, 2009 | Miele Advanta G2170SCSF Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele turbothermic G 575 SC Electronics problem?
Check the bottom tray of the unit. If water is there and the float switch is activated the drain will run and nothing else. Get rid of the water so the float switch goes off and you should be back in business. If it happens again you may have a leak somewhere and should get it looked at.
Sgt 48
Jun 03, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwasher ran with wrong soap
add some salt in the cabinet and a bit of water. salt acts as a foam suppressant
Feb 18, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele Touchtronic G892 Built-in Dishwasher Logo
563 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
