Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Possible Tuner Problem?
We have a TH-42PX50U Plasma with built in tuner connected with a cable card to the local service. We are experiencing intermitten problems receiving certain channels. Should we call repair service or complain to the cable provider? Thank you!
  • captainr8r Jan 24, 2009
    the TV is dropping channelslike 136,200 202, 302,303, 722.
Go here and get the latest firmware. Find your model on the left side of the web page. http://www.pasctraining.panasonic.com/SpecialApplications/ProductFirmwareDownloads/downloads1.asp
Posted on Sep 07, 2007
SOURCE:
How do l connect to cable
Connect the cable to the coax connector on the back called Ant. Go to setup and probably tuner. Select cable. Scan for channels.
Sep 24, 2014 | Panasonic TH-50PHD8UK 50 in. Plasma...
Panasoics plasma viera rv will not auto tune telling us to insert aerial already in Model TH-P50X20Z
The manual for this TV can be found here. If you are watching broadcast television, or cable TV service that does NOT require use of a set top "cable box" tuner, you would connect the coax cable from the UHF / VHF antenna or cable into the ANT cable connector on the rear of the TV as shown on page 8 & 9 in the manual.
You would then tell the TV setup to scan for available channels as shown on page 12 of the manual.
If you are using a seperate tuner - like those supplied by Cable TV, Dish, DirectTV, Satellite, etc. you should use (1) the HDMI 1, 2 or 3 inputs (HD) 720P and up; (2) the RGB inputs of AV2 for best picture quality 720P or better (HD), (3 & 4) the AV1 & AV3 (on the side next to HDMI) for 480i and possibly 480P (SD) and finally the ANT connector for 480i. If you have a computer that offers VGA jack to connect to an external monitor, use the PC connector on th erear of the TV to send it HD images.
Page 27 & 28 detail manual channel editing.
Mar 14, 2013 | Panasonic Viera TH-50PX80U Plasma TV
Tuner does not work
If the tuner in the set is bad connect to component or even composite inputs on the rear of the set and bypass the tuner built into the set.
What are you using for signal and what makes you think the tuner in the set is bad?
Dec 12, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
The sylvania plasma tv does not have a coaxial cable connection, how do I connect my local cable?
You just can't. Not without an external receiver.
Your TV is simply missing a piece of hardware - it is called TUNER - that can understand the signal that runs through the cable (or an antenna) and decode it into simple video signal.
So the only solution is to buy an EXTERNAL TUNER device (also called external receiver or external set top TV box).
Those are rather cheap compared with what they used to be, but if you care for an advice from professional it is: sell your TV and use the revenue towards the purchase of a new one. All TVs currently in the mainstream sales channels have that thing built-in.
Some of the older models that you will find on Craigslist (like yours) do not.
it is usually not a problem for users with cable TV because most cable TV boxes also have a built-in tuner. If you are talking about how to connect your TV to your local cable company then the right thing to do is call your cable operator and tell them you want a newer receiver that outputs standard composite (one yellow one red one white) or component (green, blue, yellow and white and red) - if your TV has the later.
Hope this helps. If it does please rate accordingly.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Screen goes black after 1-2 hours
You need to have your television tuner tested for faulty components. Your problem is caused by the components in you tuner overheating and losing functionality. The tuner need to be thoroughly test and repaired. You can reach Panasonic customer support at this telephone number. 1-888-843-9788. They should be able to tell you what the problem is and where to take it for repair. I hope this information helps you with your problem.
May 22, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Freeview not working
The tuner may be defective, or the reception is too poor for the set. A service tech who is qualified to work on your model of set can go out to your place with some field test equipment and verify the performance of the set for you.
The tuner and or IF modules, or main video processor module may be at fault. These modules can be replaced if necessary.
Before having a service call, read the instruction manual to make sure that all the user settings are correct to recieve programs from the tuner section. You can call the Panasonic tech support for assistance.
Jerry G.
Dec 18, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Game console and plasma displays
You did not list which console you have and what type of cables it has.
Looks like your plasma has:
1 component
1 composite
1 VGA
1 S-Video
If this is an xbox360 or PS3 then you will want to use the component connection, but this one is already used by the cable tuner. Don't worry there is a solution. The xbox360 and ps3 output a higher resolution that your plasma can handle, so use the component with those systems.
If it is an older console, predating the xbox360, then use the composite or S-video connections.
Since you are short on video inputs, you might need a video switch. A switch with both component and S-video connections for future add-ons.
You can find them all over the web, or your local video store like walmart and best buy. Here is a switch i found on ebay that should work:
http://tinyurl.com/3aoev9
here is the ebay search i used:
http://tinyurl.com/2ograc
Make sure you buy extra cables, most of these boxes do not come with cables, so buy what you need.
I prefer video switches that don't require a power outlet, but it's your choice. Some of the powered switches, have remotes for the lazy people, but I don't need anymore remotes on my table, keep that in mind.
Feb 14, 2008 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Plasma tv
Check the cable line thats attached to the bad set on another set side by side. If the other set still has no channels your going to need to trouble shoot or replace the tuner control bad and the tuner assy.
Sep 06, 2006 | Panasonic TH-37PX50U 37 in. HD-Ready...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
218 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
