Question about Maytag MER6772 Gemini Electric Kitchen Range
Baking Element Caught fire
The heating element in my bottom oven caught fire...literally, there were flames. I immediately turned off the oven, and teh fire died down.
  • 9 more comments
  • Anonymous Nov 18, 2007
    Mine caught fire as well. Haven't fixed it yet, but with 4 days until thanksgiving, it sucks
  • dfphilip Jan 23, 2008
    The same thing happened to my daughter's one year old GE Model JBP72 - she was told by GE that it would cost $70 for a service call plus parts and labor. The element cracking and burning does not sound like a normal occurrence. I've never heard of it before until it seems like there are minimum hits on the problem on the web. Any comments? It seems like it should be covered as a defective product!
  • Little Mike Apr 12, 2008
    top oven top heating element got so hot it was burning the insulation in the back of the stove filled my house full of smoke. only one side of the element was burning not sure what the problem is nor does Maytag. guess I will trasha 1400.00 stove
  • NonCookinmom May 11, 2008
    Just this last week our bottom oven bottom element caught fire with flames. My little girl noticed and we turned the oven off. Then I turned it on later but it would hardly heat up at all. My husband took one look and noticed the that where the fire was on the heating element it was totally broken in two. GREAT! The oven is less than two years old and minimally used. I like to use the top one. So now I'm looking at how much a new element will cost and after reading the other complaints wondering if that will be the end of it. Does anyone know if maytag will pay for any of this defect?
  • duck80 May 15, 2008
    this has happened to our jenn-aire at least four times, the last one yesterday with a pretty good fire, which I hadn't seen this bad before. It went out as soon as I shut the oven off. Rather disturbing. I've decided there must be something wrong with the oven to keep doing this. Needless to say, I need the downdraft feature which only jenn-aire makes. Anyone know what causes this to happen?
  • Anonymous Dec 22, 2008
    This just now happened to me. I heard a crackling sound in the oven and there were sparks and small flames. It burned about 60% of the element and then stopped. I also found out that my fire extinguisher(new) does not work.
  • Anonymous Jan 06, 2009
    HOW DID YOU REPLACE THE ELEMENT, DOES IT JUST PULL OUT?
  • Anonymous Jan 11, 2009
    I loved this oven - Maytag Gemini double oven #MER6770AAB, purchased on 11/28/99. But my recent problem in which the bottom oven element ignited itself and broke in two has me nervous about its safety. Is there a repair for this? Is this problem covered by Maytag? Please let me know.
  • floridamary Jan 30, 2009
    Same thing has happened to me twice, surely Maytag should have a solution for this, it could be dangerous if it happened when the house was not attended, say during a self clean? Both times I called the fire dept, very embarrassing but I was concerned at how far it would go.
  • janets59 Feb 13, 2009
    My lower oven heating element also caught on fire; I was afraid the house would burn down!
  • newbee22 Apr 03, 2009
    Where did you find the replacement element and was it easy to install by your self?
    Newbee
    [email protected]
    New Friend:
Funny same thing just happened to me and it all seams to be the bottom element of the same ovens around the same year, I bought mine in 99 also, I keep my oven very clean becasue i know the dangers it may cause, I think this is a major problem and it needs to be addressed.
Posted on Dec 11, 2009
  • Darlene Wilson
    Darlene Wilson Jun 19, 2014
    i think they should replace the element for free
I had the same problem and it was very easy to fix. The element and the wrench you need to change it are all found on repairclinic.com. I am a 30ish single woman and I did it all myself. Just be sure to unplug the range first!
Posted on Dec 20, 2009
I had the same problem. the aged heating element actually cracked and an electrical fire was happening in the bottom oven. I replaced the element - and also had to replace the temperature sensor and now it all works fine
Posted on Nov 04, 2007
SOURCE:
New element touching bottom of oven. Two small holes in over.
The element should not touch the bottom of the oven. I would call up the person that did the repair and tell them about the small holes. This may be a fire hazard. You should not be charged for work that was done improperly.
Oct 28, 2015 | Ovens
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
Hi when the oven was switched on,during the heating up there was a lot of flashing at the back of the oven and a few flames so of course it was switched off immediately after it was left to cool down we...
The oven element has shorted out.
You need to fit a new element.
This is located at the rear of the oven compartment behind a removeable cover.
A very straightforward job to do.
Feb 17, 2011 | Neff B1421 Electric Single Oven
My grandparents oven caught on fire and fried the heating element for the oven. They replaced the heating element and the oven still will not work. They used a tester and they have power going to the...
We selected this oven element based on the shape shown and the dimensions given in its .com description. It works perfectly. The oven is a built in so, as you can imagine, I was not anxious to replace it. This element was not advertised as a self cleaning oven element, but it did self clean our oven as well as the original element did. My wife and I are very pleased with this purchase.
Feb 14, 2018 | Frigidaire FEF355 Electric Kitchen Range
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 17, 2010 | Ovens
Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Feb 27, 2010 | Ovens
Elements wear out from the inside. Sooner or later it happens to all of them.
Mar 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Flame from electrice heating unit with range turned off
Your bake element blew out. Easy to replace... turn off the power (unplug) and replace the element by removing two screws holding it into the oven. Then you have two wires to the element and they either push on or have screw on terminals
Dec 22, 2008 | GE Spectra JBP78 Electric Kitchen Range
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Maytag MER6772 Gemini Electric Kitchen Range Logo
4,371 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
